Automotive MCUs
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! With any of the optimization levels (-Os size/-O1 general/-O2 speed/-O3 fast) except -O0 none, bootloader is not jumping to the application code.
Hi, I am working on SPC58NG84E7 bootloader. I have BL code(at 0xFC0000) which jumps to the APP location 0xFD0000 after waiting for 10sec after startup and executes the code there. Both codes have optimization NONE(-O0). But when BL optimization chang...
AVM by Associate III
  • 989 Views
  • 3 replies
Resolved! DMEM Processor local RAM Memory configuration Issue
Micro controller : SPC584BWe tried configuring the DMEM Processor local RAM for SPC584B Microcontroller.(Attaching the DMEM Memory layout) (We have configured it outside BAF region)We tried pushing initialized global variables to this section. We hav...
JJose.4 by Associate
  • 952 Views
  • 1 replies
How to use ICU for channels in eMOIS0 Group1 with SPC5Studio?
Hi,I am using SPC584B70E3 and I want to configure some of the inputs as an ICU. However, the SPC5Studio Limits the ICU for eMIOS0 Channels 0-7 only. I cannot configure PE[0] (eMIOS0 Channel 11 or eMIOS1 Channel 13) as ICU for instance. In the Referen...
TUyar.1 by Associate
  • 1158 Views
  • 5 replies
UDE Workspace refers to older source files
Hello,I normally copy an old SPC5 project and paste it with an updated version number to modify the source code. But, the copied UDE workspace is referring to older source code. Can you help to fix it?Thanks in advance.Br,Sreejith
SKara.7 by Associate II
  • 603 Views
  • 4 replies
Resolved! Issues with flash programming -SPC584Bxx
After flash programming, the program doesn't run once I disconnect the debugger and do a power cycling. Can somebody help me to find what the problem is? I use the attached build settings for Hex file generation in SPC5 Studio.
  • 1001 Views
  • 5 replies
