Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! What will happened when changing a default values of INPSAMPLE, INPCMP, INPLATCH, OFFSHIFT in ADC of SPC560PXX? Then how to determine The values of these bitfields?
I tried setting up with default configuration parameters for ADC 1 on the SPC560PXX. However, it provides some random values. In the conversion timing register, I verified that INPSAMPLE's SPC560PXX default value is 5. When creating a Conversion grou...
VJ.4 by Associate
  • 1128 Views
  • 1 replies
Resolved! How to SYNC PWM?
Hello, i have now this working code on SPC560P without sync flag. pwm_lld_start(&PWMD1, &pwm_config_pwm_cfg0); pwm_lld_start(&PWMD2, &pwm_config_pwm_cfg0); pwm_lld_start(&PWMD3, &pwm_config_pwm_cfg0); pwm_lld_start(&PWMD4, &pwm_config_...
How to put struct object in absolute memory address?
My old project using 16bit infineon MCU with tasking c166, now I am moving to spc5 with free gnu gcc spc5studio.I am working with typedef struct.typedef struct { struct { struct { INT16 Rpm[6]; INT16 Load[7]; INT16 Threshold[6]; }...
jmary by Associate III
  • 3667 Views
  • 11 replies
Hi Guys, I am working on SPC584B-DISP Board.In this board i need bootloader option so that i am try to use example SPC584Bxx_RLA Bootloader Test Application for Discovery 2 .In this example download code from serial UART .
In this I can able to download bin file from UART next step jump to app in this step not working if any one have idea please help .......Thanks advance ...
Ravi S by Associate II
  • 8249 Views
  • 52 replies
FLEXPWM channel setting
Hi,Can anyone explain to me about this flexpwm setting? Now my led just in condition of logic HIGH, not turning off or fade, it just ON.
Angle by Associate II
  • 588 Views
  • 0 replies
Anyone have SPC5-L9177A-K01 schematic?
Hi, recently I bought SPC5-L9177A-K01 development board from Arrow, But I received the board only. ​Is there anyone have the board schematic, since the schematics is different from SPC5-L9177A-K02 board. ​Already contact Arrow, still no result.
  • 571 Views
  • 0 replies
