Automotive MCUs
How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Help Needed: RTC Channel Configuration Issue on SPC58NN84
Hello team,I am currently working on configuring the GPT (General Purpose Timer) MCAL module for the SPC58NN84 microcontroller. While I have successfully configured PIT channels 0 and 1 for my project, I am encountering an error related to RTC (Real-...
Veer by Associate
  • 224 Views
  • 0 replies
How to set the JTAG password lock for SPC584B?
I have successfully established a connection between SPC584B and UDE STK2 as shown below:Mo 07.10.2024 14:58:50.425, Success, Core2, UDEDebugServer, Connection to SPC584B70 target established: PowerPC Target, JTAG-ID: [32bit JTAG ID] In the UDE STK m...
ishii by Associate
  • 265 Views
  • 0 replies
Stellar SR6G7 HSM2HOST IE interrupt bit information
To enable the HSM notification to application core, I understood that we need to enable HSM2HOST IE register. I would like to know which bit position of 32 bit, we need to enable to make interrupt activate ? There is no such informations in the safet...
Unable to TX using CAN in SPC58NN84E4
Hi, I'm using the SPC58NN84E7 controller for CAN communication. I have referred the this application note that has a similar implementation for SPC58ECx controller. I have configured M_CAN_2_SUB_0 hardware channel for CAN communication with a baudrat...
vallabhd_0-1727956710102.png vallabhd_1-1727956887869.png vallabhd_2-1727957013400.png
vallabhd by Associate
  • 220 Views
  • 1 replies
External flash interfacing with SPC582bxx MCU
Hello All, I am working on data storage on external flash memory, so for my application we are using SPC582Bxx MCU and W25QXX as external flash to store audio files into it. I have configured the below SPI pins to access the flash memory device, I ha...
Resolved! Can i run RTOS Task on Multi-core ??
I use spc58nh board.​I was using an RTOS Task On one core.​I want to use two core, and divide task into two cores.​​is this possible?for example : core2 - task 1, task 2 --> core 1 - task 1 , core 2 - task 2​
hans536 by Associate III
  • 887 Views
  • 4 replies
GTM DTM (Dead time Module) for SPC58NN84E7
Hello ST Community, I am currently working with the SPC58NN84E7 controller and using the AUTOSAR SPC58NN MCAL version 4.0.3.I am in the process of configuring the PWM module for our project, which requires both the GTM (for clocking the counter) and ...
Veer by Associate
  • 291 Views
  • 1 replies
