Automotive MCUs
How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! SPC5Studio license expired after 1 year trial
Hi, my license for SPC5Studio is expired after 1 year trial. Is there any way to extend this license? I do have a permanent license but it's activated on another Lab PC (connecting to a UDESTK dongle). I need to activate it on my personal PC so that ...
TBui.1 by Associate
  • 706 Views
  • 1 replies
Chorus 10M Performance Monitor APU Event Mapping
Hi,I want to utilize the Chorus 10M Performance Monitor APU. In the reference-manual rm0004-programmers-reference-manual-for-book-e-processors-stmicroelectronics.pdf Section 3.16.3 Table 55 which shows the Mapping of the PMLCax Register bits you can ...
WMuel.1 by Associate
  • 438 Views
  • 0 replies
Having Difficulties Figuring Out How to Flash the MCU
I'm using the AEK-MCU-C4MLIT1 evaluation kit for testing out the SPC58 MCU's. I have managed to write, generate, and build my program but I can't figure out how to actually upload my code onto the SPC58. I am coming from the STM32 MCU family where ...
ZGood.1 by Associate
  • 506 Views
  • 1 replies
SPC560P44L3 Center alignment PWM generation.
Controller: SPC560P44L3 (Custom board)IDE: SPC StudioIm facing problems in generating 16kHZ frequency PWM center alignment.For frequencies below 500Hz I was able to generate PWM center alignment, as per the code generation settings. But going for hig...
RRama.3 by Associate
  • 786 Views
  • 0 replies
Reset line driven low on SPC58E
Hello guys,We have designed a board based on SPC58EG40 MCU, this MCU is designed to be programmed via spc5-udestk, all the connections are fine except the Reset line which gives a value of 0.5V, even though it's pulled up to 3.3V by a 4.7Kohm Resisto...
Basel by Associate II
  • 521 Views
  • 0 replies
SPC58EC-DISP Serial Communication Sample code HELP!!!
A problem occurred during the serial communication test process with the SPC58EC-DISP board.The test environment and problem symptoms are as follows.​test environment1. Apply 12V Power to SPC58EC-DISP board2. Debugging and Serial Communication Test t...
SMOON.21 by Associate
  • 2619 Views
  • 9 replies
