Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Pinmap wizard import/export between projects?
Posted on August 28, 2015 at 16:07Hello, In SPC5 Studio V3.4.4, instead of accessing the pinmap wizard using the small icon in the HAL configuration, I created a pinmap wizard in the project using ''New -> SPC5 Studio Pinmap Wizard'' and I'm now stu...
Problem With LINFLEX1 Interrupt
Posted on August 25, 2015 at 09:44Hi In my system i set the LINFLEX1 For my Lin Connections I set this in Master Mode i send and recive correctlly the slave response but i don't have any interrupt on Vector99 what is the problem on SPCstudio ?? Tha...
driver flash SPC560B
Posted on August 21, 2015 at 16:27hello work with SPC5 v3 and chibios.i don't find the source code for Standard software driver for C90FL.to operate on the Flash module embedded on a microcontroller (SPC560B)and a exemple to used the driver.Best reg...
SPC56EL60L5CBF Exceptions
Posted on July 06, 2015 at 09:16Hello,I have a few questions regarding exceptions in microcontroller mentioned in the topic. I'm trying to cause Illegal instruction exception (IVOR6) by substituting part of hex with 0x0000. According to PowerISA v2....
dariusz by Associate II
  • 1512 Views
  • 5 replies
SPC5 examples
Posted on August 26, 2015 at 12:09HiI've installed SPC5 studio v 3.5 and I can't find nowhere these examples:http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00098036.pdf?s_searchtype=keywordWhere can I fin...
How Can i Toggle Pin in standby mode ?
Posted on August 09, 2015 at 14:55Hi members I want to toggle pin in standby mode but i do not know how can i do this ? because when i go to standby mode all things i use is disabled , i saw something lik this in freescale MCU's but i do'nt know how...
SPC5Studio configuration
Posted on August 25, 2015 at 08:27Hello,I am using SPC5Studio for SPC560D MCU. 1. How can I access CTU configuration from SPC5Studio?2. How can I configure ADC module for using CTU, one shot conversion vs scan, priorities for EOC etc?3. Any user gui...
ssk by Associate II
  • 902 Views
  • 4 replies
SPC560 - eMIOS
Posted on August 20, 2015 at 18:04Hello,I am using eMIOS module for SPC560D40L3 MCU for generating PWM. I am using default configuration for the SPCStudio project with no change to FMPLL0 and Clocks settings. My target uses 8MHz external XTAL. With ...
ssk by Associate II
  • 836 Views
  • 3 replies
SPC560 - SWT
Posted on August 12, 2015 at 15:03Hello,I am using software watchdog timer (SWT) for the SPC560D40 MCU. What is the 'out of reset' situation for the SWT?Best Regards,Mike. #swt
ssk by Associate II
  • 1000 Views
  • 5 replies
Problem with Lin Enable filters
Posted on August 12, 2015 at 11:01Hi I Have 2 problems with Lin : 1.When i Recive a data from LIN I have  No interrupt  2.When i want to set a filter in LIN the programm not work at this point in the attachment code :LINFLEX_1.IFMR.B.IFM=1; LINFLEX...
