Automotive MCUs
How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
SPC560D - power control modes
Posted on June 30, 2015 at 16:50Hello,I am using standby mode for SPC560D MCU. The datasheet mentions about using DRUN or software reset for exiting this mode. Can you please explain on,1. How to configure the DRUN mode? I tried using API 'halSPCSet...
ssk by Associate II
  • 4891 Views
  • 61 replies
SPC560B60, SPC560B64 and ''Freescale SPC5607B'' compatibility
Posted on December 07, 2015 at 12:46Good morning, I've 2 questions: First, I'm wandering about the differences between: the SPS560B60 and the SPS560B64? Are they compatible in the sense that the same code would run the same in both devices? (I'm alr...
mbahtat by Associate
  • 469 Views
  • 1 replies
using UART
Posted on November 27, 2015 at 11:13Hello everybody, I'm using the SPC56EL70L5DISP board.In order to use UART, I put the jumpers in J18 and J20 to connect UART-MCU LIN0, following the board user guide.Running the test example with UART and blinking ...
eDMA with SPC560B
Posted on November 30, 2015 at 16:05Hi all, I try to get the eDMA Modul working. My starting point is an example code from the document ''Qorivva Simple Cookbook “Hello World�? Programs to Exercise Common Features on MPC5500 & MPC5600 Microcontrolle...
dominik2 by Associate II
  • 677 Views
Using SRAM
Posted on October 30, 2015 at 12:43I am using SPC560D with SPC5Studio. I want to save the device configuration/status before putting the device to standby mode and use/retrieve this status when the device exits standby mode. Can this be achieved by ...
ssk by Associate II
  • 938 Views
  • 6 replies
SPC5Studio 3.7.1 is available !!!
Posted on November 24, 2015 at 10:24Dear All , SPC5Studio 3.7.1 is available *** Highlights *** - Documentation Update (Pinmap, ClockTree, SPC5Studio userguides) - Several bugs and improvements, please refer to https://my.st.com/public/STe2ecommuni...
eMIOS overflow callback and frequency range
Posted on October 19, 2015 at 12:20Hello, when I was working on SPC56EL with older SPC5 Studio versions, the overflow callback was called only when the internal counter was overflowing. This was perfect to detect too low frequency which can't be mea...
Updates
Posted on November 10, 2015 at 15:44Hello everybody,I tried to update SPC5 studio but i got the error ''No repository found containing:''on every update package.Trying to fix this problem I accidentally erased repositories.Now i need to know what si...
SPC5UDESTK - Checksum
Posted on October 07, 2015 at 14:48I am using Universal Debug Engine v4.02.07 for programming the flash with SPC560D MCU with PLS USB/JTAG adapter. Where can I find the checksum value for the obj file (.elf or .hex or .out)? Which menu of the tool h...
ssk by Associate II
  • 537 Views
  • 4 replies
SPC5Studio 3.7.0 is available !!!
Posted on September 18, 2015 at 13:51Dear All ,SPC5Studio 3.7.0 is available*** Highlights ***- SPC563Mxx RLA (Register Level Access) drivers for Monaco, with sample applications and related documentation - EEPROM emulation software, with sample app...
