Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! SPC56 I2C - stop bit and bus idle condition
Posted on March 11, 2015 at 14:07Hi,I'm developing an I2C driver for a SPC560B54L5 micro, and I have problems generating the stop bit.At the end of a write operation, I run the following pseudo code:   while  (0 == IBSR. IBIF) { /* wait */ }   IBCR....
fabien23 by Associate II
  • 3690 Views
  • 6 replies
Debugging SPC56EL behaves strangely
Posted on September 04, 2017 at 14:35I have a simple for loop that should ideally run 20 times, inside which I toggle an LED.When I debug this code on my SPC56EL controller (on a daughter board which is mounted onto the XP56 motherboard) WITHOUT har...
SPC58EC80E3: Issue with DMA triggering from eMIOS_SAIC
Posted on August 29, 2017 at 19:15Hello,I am trying to get eMIOS channel to capture an input in SAIC mode (Falling Edge) then trigger DMA channel after each capture in order for the DMA to copy the time stamp from the UC register A to a data buffer....
The portMacro.h of FreeRTOS
Posted on August 28, 2017 at 06:15The MPC series is a 32-bit chip.Why is FreeRTOS portSTACK_TYPE defined as a long type? I think it should be uint32 type.Because STM32 is 32-bit chip, STM32 inside the portSTACK_TYPE defined as uint32 type
[ATT]9313
Posted on August 24, 2017 at 14:46 Title Document: Tutorial : SPC5 FritzingHello SPC5 community ,we have created a new project SPC5Fritz available on githubhttps://github.com/microwan/spc5fritz this project is containing some parts for Fritzing tool...
Resolved! Clocking SPC570
Posted on August 11, 2017 at 07:17Hi,i have a Problem with the Clock Configuration of the SPC570 �C (SPC570S-DISP). I just want to use the External Clock (crystal).my Configuration:CGM_SC_DC0/CGM_SC_DC1/CGM_SC_DC2 are set to 0x80000000AC0_SC/AC1_SC/...
Resolved! Can't activate FLASH/OTP Device !
Posted on August 16, 2017 at 11:06Hello community,I have 2 SPC56EL70L5-DISP boards and I am messing around with FlexRay.Today I was not able to program one of the boards anymore (with the same code as the other board).The UDE Memtool shows the error...
FlexCAN Tx problem
Posted on July 17, 2017 at 08:50 Hello, I am working on a SPC560P Discovery Board. I have imported test application 'SPC560Pxx RLACAN Test Application for Discovery' for FlexCAN testing. In this FlexCAN0 is used in loop back mode and it is w...
Resolved! Low Level Interrupt Control Problem
Posted on November 04, 2014 at 12:58 Hello, I'm trying register base interrupt control. But not working.(problem *.s files) I do not want to use to OSAL library. Not starting interrupt. Example Code: //Orhan YILMAZ //Ti...
Resolved! SP5 Studio 5.5 Problem (CAN Issue)
Posted on August 10, 2017 at 04:321.The CANConfig structure adds a number of field information,it have a ''fifo_rx_callback'' function point.. Why is there a dialog box in SP5Studio that does not configure fifo_rx_callback?Causes the '' fifo_rx_call...
