Automotive MCUs
How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Linking external object files
Posted on October 31, 2016 at 10:05Hello,I have some closed-source library code, which I need to use in my project.If I just add the headers and the .o files to my project, when I build, I get the linker error ''undefined reference to xxx ...''. I n...
SPC5Studio IVOR2/3 Handler
Posted on November 07, 2016 at 06:10Hi,Has anyone used IVOR2/3 Handler using SPC5Studio? I would like to how to write IVOR2/3 Handler routine using SPC5Studio.Thanks and Regards,Dinesh Rode
dinesh by Associate
  • 356 Views
  • 1 replies
SPC5Studio Build and Debug Problems
Posted on October 31, 2016 at 12:57Hello,I'm new to SPC5Studio environment and experiencing some problems using it. I'll be glad if you can help about the following issues:1) When I try to create a project using steps ''File->New->C Project->Makefil...
evren by Associate
  • 397 Views
  • 1 replies
Importing SPC5Studio V3.5 project using V5.0
Posted on October 27, 2016 at 14:46Hi,I need to work on old project created using SPC5Studio V3.5. Project is created using Wizards. When I open same project using V5.0, the 'Configuration.xml' is showing some error (red cross against file name). If...
dinesh by Associate
  • 373 Views
  • 1 replies
Running code from SRAM through BAM loader
Posted on October 17, 2016 at 21:10Hello, Does SPC5Studio provide a way to configure the toolchain to link code to the appropriate address to run from the BAM bootloader, or should I just modify the generated application.ld as I see fit? My goal is ...
SPC5 studio - placing variables at fixed RAM addresses
Posted on September 27, 2016 at 10:54Hello everyone.I�m working on a Bolero microcontroller (SPC560D40L3) using SPC5Studio and Hightec Compiler.I have a question related to variables to be located in RAM.I have a set of global variables, which I nee...
SPC563M64 JATG uncensoring through USB Multilink
Posted on October 13, 2016 at 23:50Hi all. I have some trouble to connect SPC563M64 through USB Multilink. My device is in censored mode with configuration 0xAAAA_AAAA and serial password 0x1122334455667788. I try to uncensor device with this passwo...
cbnsspb by Associate
  • 434 Views
  • 1 replies
PLS UDE and Windows 10
Posted on September 21, 2016 at 11:28Dear All ,in case of Connexion issues with PLS (FTDI Issues) and Discovery Board.Please , install the the last software (4.07.04) coming from PLS websitehttp://www.pls-mc.com/download-spc5-udestk/downloads-a-1626...
Use of timers with large software
Posted on September 13, 2016 at 15:16Good day to everyone,I am writing here in order to have some suggestions on the use of timers. I am writing a spc5 application whee I have a lot of operations and I must do various things at specific moments. For...
Help For using Os in SpcStudio
Posted on August 28, 2016 at 10:16Hi I have new Project , for this project i want to use an OS for my core I don't know how can i use this oses and are they have any license for using in spcstudio ? Thanks For Help With Best Regards Nazerian Vani...
