Automotive MCUs
How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! SPC572 Ethernet
There is no Network Component RAL avaliable for our SPC572L64E3 controller.Is there a app note or sample application that we look at to get started with this.
Larsa by Associate II
  • 385 Views
  • 1 replies
SPC570S CAN RX FIFO
Hi Everyone, I'm working with CAN RX FIFO in SPC570S Dev board.Anyone can help me to change this ID acceptance mask to Format B? Best regards,Yohan
RX FIFO configuration in SPC570S
Hi Everyone, I'm using RX FIFO callback when receiving CAN messages from the ID table in my SPC570S Dev board. According to the reference manual, it only can receive & interrupt the messages from the first 8 IDs (0 to 7) in the table. Is there any wa...
Resolved! BSDL file for SPC560B54L3C6E0X
I need the BSDL file (Boundary Scan Description Language ) for SPC560B54L3C6E0X device, but I cannot find it on your web site. Can you send to me?NOTE: This question and answer originated from a customer support case which was handled by us. We regul...
SPC58NN HSM information
Hi,Can someone elaborate on  the Key update programming process for SPC58NN84 controller or any document which can provide this information.
sonal by Associate
  • 248 Views
  • 0 replies
SPC572 with SARADC in DMA mode
We have the SARADC up and running in DMA mode on 1 channel as per the sample application.But when we add 2 more channels we can't get it to go throgh the callback routin. (saradcconfdma_ch1_conf_cb & saradcconfdma_ch2_conf_cb) and hence we don´t get ...
  • 576 Views
  • 0 replies
SARADC errors after SPC5 uppgrade
Worked perfect 2 years ago, then after updating the SPC5Studio we can´t get the SARADC to compile without alot of errors in the saradc_lld_cfg.c file (attached picture). We tried to use the old saradc_lld_cfg.c file and we could compile it but the ad...
  • 631 Views
  • 1 replies
