STM32CubeMX v.4.8 with MDK-ARM v.5.15
Question asked by palitsky.gennady on Jul 2, 2015
Latest reply on Jul 4, 2015 by palitsky.gennady
I am trying to generate initialization code for STM32F427ZITx.
Clock and peripherals configuration in a CubeMX is OK.
Code generation is OK.
All main files (startup, system, HAL drivers, initialization routines) in a generated project seem to be in place,
But, when I open a generated project in MDK-ARM, nothing seems to be configured in a Run-Time Environment. And, as far as I understand, the Cube should take care of it.
The configuration project builds fine in MDK. But when I am trying to run a debug session, it starts at 0x1FFF5162, and, of coarse, doesn't run.
Loading application to the flash doesn't work either.
Am I missing something?
I tried to research the problem, but the only related document I was able to find is a year old Keil app note on integration of CubeMX into MDK. They recommend to use some very outdated (v.1) family pack.
I can write configuration manually in MDK, but don't want to miss the great CubeMX's capability to reconfigure on a fly.
Will appreciate any advice on a subject.
Thank you,
Gennady
