STM32CubeMX USB HS Mass Storage Class code 10
Question asked by Slalen on Jun 17, 2015
Latest reply on Jun 22, 2015 by chahrayar.chahrazed
I have an STM3240G-EVAL board and I try to configure the USB-HS with the SD-Card.
I have seleccted:
- USB-OTG-HS: External Phy - Device_Only
- SDIO: Mode - SD 1 bit
- USB_DEVICE: Class For HS IP: Mass Storage Class
And I have only  generated the code. I have not change anything.
In the code I change it:
  * @file           : usbd_storage_if.c
  * @brief          : Memory management layer
  * COPYRIGHT(c) 2015 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  * 1. Redistributions of source code must retain the above copyright notice,
  * this list of conditions and the following disclaimer.
  * 2. Redistributions in binary form must reproduce the above copyright notice,
  * this list of conditions and the following disclaimer in the documentation
  * and/or other materials provided with the distribution.
  * 3. Neither the name of STMicroelectronics nor the names of its contributors
  * may be used to endorse or promote products derived from this software
  * without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "usbd_storage_if.h"
#include "stm32f4xx_hal_sd.h"
/* USB handler declaration */
/* Handle for USB High Speed IP */
USBD_HandleTypeDef  *hUsbDevice_1;
extern USBD_HandleTypeDef hUsbDeviceHS;
extern SD_HandleTypeDef hsd;
extern HAL_SD_CardInfoTypedef SDCardInfo;
/* Extern function prototypes ------------------------------------------------*/
#define STORAGE_LUN_NBR                  1
#define STORAGE_BLK_NBR                  0x10000
#define STORAGE_BLK_SIZ                  0x200
static int8_t STORAGE_Init_HS (uint8_t lun);
static int8_t STORAGE_GetCapacity_HS (uint8_t lun,
                           uint32_t *block_num,
                           uint16_t *block_size);
static int8_t  STORAGE_IsReady_HS (uint8_t lun);
static int8_t  STORAGE_IsWriteProtected_HS (uint8_t lun);
static int8_t STORAGE_Read_HS (uint8_t lun,
                        uint8_t *buf,
                        uint32_t blk_addr,
                        uint16_t blk_len);
static int8_t STORAGE_Write_HS (uint8_t lun,
                        uint8_t *buf,
                        uint32_t blk_addr,
                        uint16_t blk_len);
static int8_t STORAGE_GetMaxLun_HS (void);
/* USER CODE BEGIN 1 */
/* USB Mass storage Standard Inquiry Data */
const int8_t  STORAGE_Inquirydata_HS[] = {//36
  /* LUN 0 */
  0x00,
  0x80,
  0x02,
  0x02,
  (STANDARD_INQUIRY_DATA_LEN - 5),
  0x00,
  0x00,
  0x00,
  'S', 'T', 'M', ' ', ' ', ' ', ' ', ' ', /* Manufacturer : 8 bytes */
  'P', 'r', 'o', 'd', 'u', 'c', 't', ' ', /* Product      : 16 Bytes */
  '0', '.', '0' ,'1',                     /* Version      : 4 Bytes */
/* USER CODE END 1 */
USBD_StorageTypeDef USBD_Storage_Interface_fops_HS =
  STORAGE_Init_HS,
  STORAGE_GetCapacity_HS,
  STORAGE_IsReady_HS,
  STORAGE_IsWriteProtected_HS,
  STORAGE_Read_HS,
  STORAGE_Write_HS,
  STORAGE_GetMaxLun_HS,
  (int8_t *)STORAGE_Inquirydata_HS,
* Function Name  : STORAGE_Init_HS
* Description    :
* Input          : None.
* Output         : None.
* Return         : None.
  /* USER CODE BEGIN 9 */
  return (USBD_OK);
  /* USER CODE END 9 */
* Function Name  : STORAGE_GetCapacity_HS
* Description    :
* Input          : None.
* Output         : None.
* Return         : None.
int8_t STORAGE_GetCapacity_HS (uint8_t lun, uint32_t *block_num, uint16_t *block_size)
  /* USER CODE BEGIN 10 */
    HAL_SD_Get_CardInfo (&hsd, &SDCardInfo);
    * block_num = SDCardInfo.CardCapacity / SDCardInfo.CardBlockSize;
    * block_size = SDCardInfo.CardBlockSize;
  return (USBD_OK);
  /* USER CODE END 10 */
* Function Name  : STORAGE_IsReady_HS
* Description    :
* Input          : None.
* Output         : None.
* Return         : None.
  /* USER CODE BEGIN 11 */
  return (USBD_OK);
  /* USER CODE END 11 */
* Function Name  : STORAGE_IsWriteProtected_HS
* Description    :
* Input          : None.
* Output         : None.
* Return         : None.
  /* USER CODE BEGIN 12 */
  return (USBD_OK);
  /* USER CODE END 12 */
* Function Name  : STORAGE_Read_HS
* Description    :
* Input          : None.
* Output         : None.
* Return         : None.
                        uint8_t *buf,
                        uint32_t blk_addr,
                        uint16_t blk_len)
  HAL_SD_ReadBlocks(&hsd, (uint32_t*)buf, (uint64_t)(blk_addr * SDCardInfo.CardBlockSize), SDCardInfo.CardBlockSize, blk_len);
  return (USBD_OK);
  /* USER CODE END 13 */
* Function Name  : STORAGE_Write_HS
* Description    :
* Input          : None.
* Output         : None.
* Return         : None.
                         uint8_t *buf,
                         uint32_t blk_addr,
                         uint16_t blk_len)
  HAL_SD_WriteBlocks(&hsd, (uint32_t*)buf, (uint64_t)(blk_addr * SDCardInfo.CardBlockSize), SDCardInfo.CardBlockSize, blk_len);
  return (USBD_OK);
  /* USER CODE END 14 */
* Function Name  : STORAGE_GetMaxLun_HS
* Description    :
* Input          : None.
* Output         : None.
* Return         : None.
  /* USER CODE BEGIN 15 */
  return (STORAGE_LUN_NBR - 1);
  /* USER CODE END 15 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
And when I conect the USB i have the error Code 10 in windows.
What's wrong??
