Java exception when running cube 4.8.0 on Linux
Question asked by Burton.Mark on Jun 15, 2015
Latest reply on Jul 1, 2015 by STM32Cube-T
My STM32CubeMX.log file shows the following backtrace when I try to configure a GPIO pin and the panel at the bottom of the dialog that should show the configuration controls is empty.
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
    at com.st.microxplorer.plugins.ip.gpio.gui.ParameterUI.addPropertyChangeListener(ParameterUI.java:156)
    at javax.swing.plaf.synth.SynthPanelUI.installListeners(SynthPanelUI.java:83)
    at javax.swing.plaf.synth.SynthPanelUI.installUI(SynthPanelUI.java:63)
    at javax.swing.JComponent.setUI(JComponent.java:665)
    at javax.swing.JPanel.setUI(JPanel.java:153)
    at javax.swing.JPanel.updateUI(JPanel.java:126)
    at javax.swing.JPanel.<init>(JPanel.java:86)
    at javax.swing.JPanel.<init>(JPanel.java:109)
    at javax.swing.JPanel.<init>(JPanel.java:117)
    at com.st.microxplorer.plugins.ip.gpio.gui.ParameterUI.<init>(ParameterUI.java:72)
    at com.st.microxplorer.plugins.ip.gpio.gui.ParameterUI.<init>(ParameterUI.java:101)
    at com.st.microxplorer.plugins.ip.gpio.gui.ComboParameterUI.<init>(ParameterUI.java:431)
    at com.st.microxplorer.plugins.ip.gpio.gui.ParamContainer.createPanel(ParamContainer.java:97)
    at com.st.microxplorer.plugins.ip.gpio.gui.ParamContainer.update(ParamContainer.java:145)
    at com.st.microxplorer.plugins.ip.gpio.gui.GpioTablePanel$RowListener.valueChanged(GpioTablePanel.java:192)
    at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:184)
    at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:154)
    at javax.swing.DefaultListSelectionModel.setValueIsAdjusting(DefaultListSelectionModel.java:685)
    at javax.swing.plaf.basic.BasicTableUI$Handler.setValueIsAdjusting(BasicTableUI.java:953)
    at javax.swing.plaf.basic.BasicTableUI$Handler.mouseReleased(BasicTableUI.java:1166)
    at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
    at java.awt.Component.processMouseEvent(Component.java:6516)
    at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
    at java.awt.Component.processEvent(Component.java:6281)
    at java.awt.Container.processEvent(Container.java:2229)
    at java.awt.Component.dispatchEventImpl(Component.java:4872)
    at java.awt.Container.dispatchEventImpl(Container.java:2287)
    at java.awt.Component.dispatchEvent(Component.java:4698)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
    at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
    at java.awt.Container.dispatchEventImpl(Container.java:2273)
    at java.awt.Window.dispatchEventImpl(Window.java:2719)
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747)
    at java.awt.EventQueue.access$300(EventQueue.java:103)
    at java.awt.EventQueue$3.run(EventQueue.java:706)
    at java.awt.EventQueue$3.run(EventQueue.java:704)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
    at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
    at java.awt.EventQueue$4.run(EventQueue.java:720)
    at java.awt.EventQueue$4.run(EventQueue.java:718)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:717)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154)
    at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182)
    at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221)
    at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219)
    at java.awt.Dialog.show(Dialog.java:1082)
    at java.awt.Component.show(Component.java:1655)
    at java.awt.Component.setVisible(Component.java:1607)
    at java.awt.Window.setVisible(Window.java:1014)
    at java.awt.Dialog.setVisible(Dialog.java:1005)
    at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.createIpDialog(BlockDiagram.java:348)
    at com.st.microxplorer.plugins.ipmanager.gui.BlockDiagram.actionPerformed(BlockDiagram.java:271)
    at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
    at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
    at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
    at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
    at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
java version "1.7.0_80"
Java(TM) SE Runtime Environment (build 1.7.0_80-b15)
Java HotSpot(TM) Server VM (build 24.80-b11, mixed mode)
