How to config STM32CubeMX 4.8.0, to make this PWM config Code ?
Question asked by wjandsq on Jun 14, 2015
Latest reply on Jun 23, 2015 by chahrayar.chahrazed
uint32_t SystemCoreClock = 168000000;
uint32_t TIM4_PWM_frequency;
uint16_t TIM4_CCR1_SRC[1024];
uint16_t DMA1_TIM4_Pulse_Number = 10;
  * @brief  Configure the TIM4 CH1 as PWM out.
  * @param  None
  * @retval None
  * made by wjandsq@163.com
void TIM4_PWM_DMA_Config(void)
  DMA_InitTypeDef DMA_InitStructure;
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  uint16_t uhTimerPeriod = 0;
  uint16_t i;
  TIM4_PWM_frequency = 500000; // 500KHz
  uhTimerPeriod = (uint16_t) ((SystemCoreClock /2) / TIM4_PWM_frequency) - 1;
  TIM4_CCR1_SRC[0] = uhTimerPeriod / 2;
  for(i = 1; i < 1024; ++i){
    TIM4_CCR1_SRC[i] = TIM4_CCR1_SRC[0];
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
#ifdef USE_PB6_PWM
  // TIM4_CH1_PWM: USE_PB6
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  /* GPIOB Configuration: TIM4 CH1 (PB6) */
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_DOWN;
  GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_Init(GPIOB, &GPIO_InitStruct);
  /* Connect TIM4 pins to AF2 */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_TIM4);
#else
  // TIM4_CH1_PWM: USE_PD12
  /** TIM4 GPIO Configuration
    PD12      ------> TIM4_CH1
    PD13      ------> TIM4_CH2
    PD14      ------> TIM4_CH3
    PD15      ------> TIM4_CH4
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
  /* GPIOB Configuration: TIM4 CH1 (PD12) */
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12;
  GPIO_Init(GPIOD, &GPIO_InitStruct);
  /* Configure GPIO pin alternate function */
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_TIM4);
#endif
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1 , ENABLE);
  DMA_DeInit(DMA1_Stream6);
  DMA_InitStructure.DMA_Channel = DMA_Channel_2;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) &(TIM4->CCR1);
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) TIM4_CCR1_SRC;
  DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  DMA_InitStructure.DMA_BufferSize = DMA1_TIM4_Pulse;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA1_Stream6, &DMA_InitStructure);
  /* TIM4_CCR1 DMA1_Stream6 Channel 2 */
  DMA_ITConfig(DMA1_Stream6, DMA_IT_TC, ENABLE);
  NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream6_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = uhTimerPeriod;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM4->CNT = 0;
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_Pulse = TIM4_CCR1_SRC[0];
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OC1Init(TIM4, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM4, ENABLE);
//  TIM_Cmd(TIM4, ENABLE);
  TIM_GenerateEvent(TIM4, TIM_EventSource_Update);
  /* TIM4 Update DMA Request enable */
  TIM_DMACmd(TIM4, TIM_DMA_Update, ENABLE);
  TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
void main(){
  TIM4_PWM_DMA_Config();
  while(1){
    // for send 10 Pulse
    TIM4->CNT = 0;
    TIM4->CR1 &= ~TIM_CR1_OPM;
    TIM4->CR1 |= TIM_CR1_CEN;
    DMA1_Stream2->NDTR = DMA1_TIM4_Pulse_Number;
    DMA_Cmd(DMA1_Stream2, ENABLE);
  * @brief  This function handles DMA1_Stream4 global interrupt request.
  * @param  None
  * @retval None
  * @brief  This function handles DMA1_Stream0 global interrupt request.
  * @param  None
  * @retval None
void DMA1_Stream6_IRQHandler(void)
  if (DMA_GetITStatus(DMA1_Stream6, DMA_IT_TCIF6) != RESET) {
    DMA_Cmd(DMA1_Stream6, DISABLE);
    DMA_ClearITPendingBit(DMA1_Stream6, DMA_IT_TCIF6);
    TIM4->CR1 |= TIM_CR1_OPM; // End PWM
