Maximal toggling frequency of STM8
Question asked by zanca.dalibor on Oct 7, 2016
I have just started with STM8 and would like to found the fastest toggling method.
Currently I have best result with following code:
     while (1)
#pragma asm
          push     A
          pushw     X
          ld          A, #1          // toggle with pin D0
          ldw          X, #0x500f     // GPIOD (port D output latch)
          clr          (X)
          ld          (X), A
          clr          (X)
          ld          (X), A
          clr          (X)
          ld          (X), A
          clr          (X)
          ld          (X), A
          clr          (X)
          ld          (X), A
          clr          (X)
          ld          (X), A
          popw     X
          pop          A
#pragma endasm
The block of 6x CLR / LD makes "bit clear" / "bit set".
Size of both instructions is 1 byte, so fetching shouldn't cause any delay.
The result is Low 62.5ns / High 125ns (i.e. 1c/2c @16MHz), repeating 6x.
I don't understand why the 1c/1c toggling is not achieved.
I would like to ask for explanation of this and solution for 1c/1c toggling (if possible).
