LPS22HB Help
Question asked by mcgrath.kristofer on Mar 25, 2016
Latest reply on May 12, 2016 by Licciardello.Antonel
I am working with the LPS22HB pressure sensor and I cannot get a response from it. I have ctrl_reg1 set as 01000000, ctrl reg 2 set as 00011000, and everything else as default.
I am using a 1MHz SPI clock and a CS pin (low - active).
I then write to the pressure_XL register and retrieve the first byte then consecutively retrieve the L and H bytes using the iterative data collecting (ctrl_reg2 enabled).
i am operating at 2.5V and am correctly sending the right bytes (measured the outputs of my microcontroller)
Why am I getting no response?
