Using STemWin with STM32F4Discovery and SSD1289 display
Question asked by Fabio_IT on Jan 6, 2015
Latest reply on Jan 15, 2015 by Montassar BEN ROMDHANE
Hi guys, I need again a big help from you. I'm trying to use the STemWin software with STM32F4Discovery, without success for the moment. I followed these steps:
  1. Get examples for STM324x eval board
  2.
  3. Modify the driver to work with SSD1289
The display module is connected through FSMC and my driver for SSD1289 works perfectly but when adapted for STemWin, the program stucks at the function GUI_Init().
This is the SSD1289 code adapted:
*          Portions COPYRIGHT 2014 STMicroelectronics                *
*          Portions SEGGER Microcontroller GmbH & Co. KG             *
*        Solutions for real time microcontroller applications        *
*        (c) 1996 - 2013  SEGGER Microcontroller GmbH & Co. KG       *
*        Internet: www.segger.com    Support:  support@segger.com    *
** emWin V5.22 - Graphical user interface for embedded applications **
All  Intellectual Property rights  in the Software belongs to  SEGGER.
emWin is protected by  international copyright laws.  Knowledge of the
source code may not be used to write a similar product.  This file may
only be used in accordance with the following terms:
The  software has  been licensed  to STMicroelectronics International
N.V. a Dutch company with a Swiss branch and its headquarters in Plan-
les-Ouates, Geneva, 39 Chemin du Champ des Filles, Switzerland for the
purposes of creating libraries for ARM Cortex-M-based 32-bit microcon_
troller products commercialized by Licensee only, sublicensed and dis_
tributed under the terms and conditions of the End User License Agree_
ment supplied by STMicroelectronics International N.V.
Full source code is available at: www.segger.com
We appreciate your understanding and fairness.
File        : LCDConf.c
Purpose     : Display controller configuration (single layer)
---------------------------END-OF-HEADER------------------------------
  * @file    LCDConf_stm3240g_eval.c
  * @author  MCD Application Team
  * @version V1.1.2
  * @date    28-January-2014
  * @brief   Driver for STM3240G-EVAL board LCD
  * @attention
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
#include "GUI.h"
#include "GUIDRV_FlexColor.h"
#include "global_includes.h"
*       Layer configuration (to be modified)
// Physical display size
#define XSIZE_PHYS  240
#define YSIZE_PHYS  320
*       Configuration checking
#ifndef   VXSIZE_PHYS
  #define VXSIZE_PHYS XSIZE_PHYS
#endif
#ifndef   VYSIZE_PHYS
  #define VYSIZE_PHYS YSIZE_PHYS
#endif
#ifndef   XSIZE_PHYS
  #error Physical X size of display is not defined!
#endif
#ifndef   YSIZE_PHYS
  #error Physical Y size of display is not defined!
#endif
#ifndef   GUICC_565
  #error Color conversion not defined!
#endif
#ifndef   GUIDRV_FLEXCOLOR
  #error No display driver defined!
#endif
*       Defines, sfrs
// COG interface register addr.
#define LCD_BASE           ((uint32_t)(0x60000000 ))
#define LCD_REG_ADDRESS   (*((volatile unsigned short *) 0x60000000))//(*(volatile U16*)LCD_BASE)
#define LCD_DATA_ADDRESS  (*((volatile unsigned short *) 0x60020000))//(*(volatile U16*)(LCD_BASE + 0x00020000))
*       Local functions
*       LcdWriteReg
* Function description:
*   Sets display register
static void LcdWriteReg(U16 Data) {
  LCD_REG_ADDRESS = Data;
*       LcdWriteData
*   Writes a value to a display register
static void LcdWriteData(U16 Data) {
  LCD_DATA_ADDRESS = Data;
*       LcdWriteDataMultiple
*   Writes multiple values to a display register.
static void LcdWriteDataMultiple(U16 * pData, int NumItems) {
  while (NumItems--) {
    LCD_DATA_ADDRESS = *pData++;
*       LcdReadDataMultiple
*   Reads multiple values from a display register.
static void LcdReadDataMultiple(U16 * pData, int NumItems) {
    *pData++ = LCD_DATA_ADDRESS;
*       Public functions
*       LCD_X_Config
*   Called during the initialization process in order to set up the
*   display driver configuration.
void LCD_X_Config(void) {
  GUI_DEVICE * pDevice;
  CONFIG_FLEXCOLOR Config = {0};
  GUI_PORT_API PortAPI = {0};
  // Set display driver and color conversion
  pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_565, 0, 0);
  // Display driver configuration, required for Lin-driver
  LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
  LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
  // Orientation
  Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
  GUIDRV_FlexColor_Config(pDevice, &Config);
  // Set controller and operation mode
  PortAPI.pfWrite16_A0  = LcdWriteReg;
  PortAPI.pfWrite16_A1  = LcdWriteData;
  PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
  PortAPI.pfReadM16_A1  = LcdReadDataMultiple;
  GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66702, GUIDRV_FLEXCOLOR_M16C0B16);
*       LCD_X_DisplayDriver
*   This function is called by the display driver for several purposes.
*   To support the according task the routine needs to be adapted to
*   the display controller. Please note that the commands marked with
*   'optional' are not cogently required and should only be adapted if
*   the display controller supports these features.
* Parameter:
*   LayerIndex - Index of layer to be configured
*   Cmd        - Please refer to the details in the switch statement below
*   pData      - Pointer to a LCD_X_DATA structure
* Return Value:
*   < -1 - Error
*     -1 - Command not handled
*      0 - Ok
int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData) {
  int r;
  (void) LayerIndex;
  (void) pData;
  switch (Cmd) {
  case LCD_X_INITCONTROLLER: {
    /* Already Done */
    //SSD1289_Init();
    return 0;
  default:
    r = -1;
  return r;
/*************************** End of file ****************************/
Any ideas?
