CXSTM8 bug when writing to bit structure
Question asked by WoRo on Oct 11, 2012
Latest reply on Oct 12, 2012 by WoRo
To optimize the code I put nearly all the flags to bit structures. Now I came across a  bug in the CXSTM8 when writing to bits. Reading bits doesn't bring any problem.
The good news for me is that I found a workaround.
Here is the example:
typedef struct
   int    sem_on  :1;  /* bit */
   int    sem_off :1;
/* bit */
   int    sem_tog :1;  /* bit */
} key_;
/*struct*/ key_ key_x;
/*struct*/ key_* key_down = &key_x;
#pragma section const {}
/*struct*/ key_* const key_up = &key_x;
 void clear_key_updown(void)
/*struct*/ key_* p_key;
   key_down->sem_on = 0;  /* variable pointer ..
   - ******** ERROR:  bad addressing mode  *********/
   (*key_down).sem_on = 0;
/* alternate expression ..
   p_key = key_down;      /* pointer substitution - o.k. */
   p_key->sem_on  = 0;
   key_up->sem_on   = 0;   /* const pointer - o.k. */
   (*key_up).sem_on = 0;   /* alternate expression - o.k. */
/*---------end of file------------------------------*/
The workaround you can see is to substitute the specific pointers.
 WoRo
