STM8L Sleep Speed
Question asked by Murat Ursavas [KMT] on Oct 8, 2012
Latest reply on Oct 9, 2012 by Murat Ursavas [KMT]
OK, title sounds really weird, but I'm really curious about the low pawer state switch speed of the STM8L micro.
I'm doing some tests about switching to LSE and back to HSI, waiting for stablization etc. It looks like the core is acting really slow, or I'm doing something really wrong.
Let me share my findings with you, and then please share your ideas with me.
Note: I'm switching ON and OFF a GPIO to measure the passed time via scope. Therefore it could be good to keep in mind the switching time. I'm trying to simulate low power entrance and exit therefore you'll  see opposite commands in same blocks.
Here is a block of code. It runs in 630 us.
CLK_SYSCLKSourceConfig(CLK_SYSCLKSource_LSE);
CLK_SYSCLKSourceConfig(CLK_SYSCLKSource_HSI);
I'm widening the test and cover switch command. Runs in 1,09 ms.
CLK_SYSCLKSourceSwitchCmd(ENABLE);
Adding stability check and runs in 1,49 ms
while (CLK_GetSYSCLKSource() != CLK_SYSCLKSource_LSE);
while (CLK_GetSYSCLKSource() != CLK_SYSCLKSource_HSI);
Adding HSI enable disable procedure, completes in  2,30 ms
CLK_HSICmd(DISABLE);
CLK_HSICmd(ENABLE);
Finally adding ULP Voltage Regulator enable disable procedure, finishes in 3,23 ms
PWR_UltraLowPowerCmd(ENABLE);
PWR_UltraLowPowerCmd(DISABLE);
CLK_HSICmd(ENABLE);
These results are really disappointing. There is no code for Peripheral Clock Gating and GPIO Switching or Interrupt clearance before the halt operation. Even so, it still takes almost 5 ms.
Is it really so or am I missing something serious...
Please share your low power ideas with me, don't think they are not related, they might be.
Thanks in advance.
P.S: I need as loweest state as possible with RTC timer enabled.
