ST Motor Control Workbench Under Voltage Fault
Question asked by bujak.daniel on Feb 18, 2016
Latest reply on Apr 1, 2016 by Gigi
I'm using the ST Motor Control Workbench with STEVAL-IFN003V1 and my bus voltage is reading above the threshold but the Under Voltage fault light is constantly on even if I disable the low voltage checking in the settings. What could the issue be? Also, is there any documentation available to explain what these faults mean exactly and how to use the application?
