STM32L451 strange RTC issue
Question asked by hage.mike on Jul 11, 2018
Latest reply on Jul 12, 2018 by waclawek.jan
I'm curious if anyone else has seen this issue.
We are using 20 ppm LSE at 32768hz as the clock source for our RTC.  Over an 8 hour period, we are a few seconds off vs. the expected max of .6 S for the 20 ppm.
Our system clock is derived from a 14Mhz ± 10ppm crystal oscillator PLL'd to 70Mhz.
We set up a test to capture the number of system clocks at the RTC one second rollover.  From the data below, you can see most readings are spot on and some have slight software jitter that corrects itself on the next one second rollover.  The problem is every 19 seconds, there is a strange offset applied.  This doesn't correspond with any settings for the smooth calibration.  I'm sure I could add smooth calibration to get rid of it, but what is it?
NOTE:  These are the deltas, not the actual counts
69650000
70000000
70000000
70000000
70000006
69999994
70000006
69999994
70000000
70000000
70000000
70000000
70000000
70000000
70000000
70000000
70000000
70000000
70000000
69650000
