USB Host FreeRTOS Assertion fails
Question asked by Johanan on Oct 31, 2014
Latest reply on Nov 3, 2014 by Johanan
As soon as the USB disk is connected, I get an assertion fail, with this comment above this assertion:
/* The following assertion will fail if a service routine (ISR) for
               an interrupt that has been assigned a priority above
               configMAX_SYSCALL_INTERRUPT_PRIORITY calls an ISR safe FreeRTOS API
               function.  ISR safe FreeRTOS API functions must *only* be called
               from interrupts that have been assigned a priority at or below
               configMAX_SYSCALL_INTERRUPT_PRIORITY.
 configASSERT( ucCurrentPriority >= ucMaxSysCallPriority );
I tried to change the OTG_FS_IRQn priority as follows:
HAL_NVIC_SetPriority(OTG_FS_IRQn, configMAX_SYSCALL_INTERRUPT_PRIORITY+1, 0);
But this did not make any change.
I found this happand just as soon as this is called:
 osMessagePut ( phost->os_event, USBH_PORT_EVENT, 0);
Any ideas how to fix this?
