High side switch VN7003ALH in parallel
Question asked by Matteo Conti on Jun 19, 2018
Latest reply on Jun 25, 2018 by Matteo Conti
I'm interested in developing an application involving the high side switch VN7003ALH. In particular I was interested in putting more of these switches in parallel in order to split the current load. In order to read the total current that flows through the switches will it be sufficient to use a voltage summer with an op-amp that receives the CS pin output currents?
Is there other attentions to be aware in a parallel configuration?
Thank you very much,
Best regards,
Matteo
