how to generate PWM in LED
Question asked by ABDELAOUI samira on Jun 7, 2018
Latest reply on Jun 8, 2018 by ABDELAOUI samira
Hello
I want to generate PWM wih LEDs. From where I should start ? ?
the LEDs arein GPIO G port G but in the same port there is the pins of ethernet also. How can I do to touch only the part of LEDS and not the ethernet part with PWM  please ?
I used timer 14 for example with CubeMX in mode " compare output no  output " . Is it correct pleasae ?
If yes what are the next steps ?
Thank you in advance for your reply
