RTC Interrupt not accurate when place a function in
Question asked by jd kim on May 12, 2018
I just used RTC interrupt to measure msec timing. and  I got some problem.
when i write naive code in interrupt there is no problem. timing is correct and no delay. the sample code is below
void RTC_IRQHandler(void)
   val = RTC->CNTL ;
   dif = val - ex;
   msec++;
   if (msec >= 1000)
   sec++;
   msec = 0;
   ex = RTC->CNTL ;
 but when i use a function to replace with the code the timing have delay almost half
   val = RTC->CNTL ;
   dif = val - ex;
   timing(); // just same with previous code.
   ex = RTC->CNTL ;
void timing()
   msec_++;
   if (msec_ >= 1000)
   sec_++;
   msec_ = 0;
to clarify, i write the two code in same time. but change nothing
   val = RTC->CNTL ;
   dif = val - ex;
   msec++;
   if (msec >= 1000)
   sec++;
   msec = 0;
   timing(); // the timing is same and also has same delay
   ex = RTC->CNTL ;
wtf? I didn't change any clock config. why this interrupt is not occur in correct timing when i use any simple function?
