STM32F0 ADC Scan Int Issue
Question asked by ressel.tim on Apr 18, 2018
Latest reply on Apr 18, 2018 by Clive One
Hi, I am trying to set up an STM32f030 to do ADC conversions on 4 channels using interrupts and no DMA. The first ADC input gets good values but the second ADC inf put is wonky.I used CubeMX to generate the code. I am a noob and wish to get the ADC working before diving into DMA. Any help would be appreciated.#
Here is the code:
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* AdcHandle)
    switch(CurChannel)
    case 0:
        Adc_Raw_X = HAL_ADC_GetValue(AdcHandle);
        CurChannel++;
        AvgAdc[0]+=Adc_Raw_X;
        cntAvgAdc[0]+=1;
        if(cntAvgAdc[0]>=16)
            cntAvgAdc[0] = 0;
            AvgAdc[0] = AvgAdc[0] / 16;
            flgInputChanged=1;
        break;
    case 1:
        Adc_Raw_Y = HAL_ADC_GetValue(AdcHandle);
        CurChannel++;
        AvgAdc[1]+=Adc_Raw_Y;
        cntAvgAdc[1]+=1;
        if(cntAvgAdc[1]>=16)
            cntAvgAdc[1] = 0;
            AvgAdc[1] = AvgAdc[1] / 16;
            flgInputChanged=1;
        break;
    case 2:
        Adc_Spare1 = HAL_ADC_GetValue(AdcHandle);
        CurChannel++;
        break;
    case 3:
        Adc_Spare2 = HAL_ADC_GetValue(AdcHandle);
        CurChannel++;
        HAL_ADC_Stop_IT(&hadc);
        break;
static void MX_ADC_Init(void)
  ADC_ChannelConfTypeDef sConfig;
    /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  //hadc.Init.EOCSelection = ADC_EOC_SINGLE_SEQ_CONV;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.DMAContinuousRequests = DISABLE;
  hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
    /**Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_2;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_3;
    Error_Handler();
