TIM3 OC problem
Question asked by n.serina on Apr 17, 2018
Latest reply on Apr 19, 2018 by n.serina
Hello ,
I am using NUCLEOf446re board and i have some issues with TIM3 OC getting 50Kz waveform on channel 1 .
when i derive systemclock from PLL . it works fine .
systemclock = 180Mhz
APB1CLK = 45MHz
TIM3CLK = 90Mz
prescaler of timer= 9
timer cnt clk = 9Mhz  ..
OC pulse value = 9000000/50000
this configuration work fine .
but when i switch to HSI , the code doesnt work .
in HSI i use the below config
systemclock = 16Mhz
APB1CLK  = 16Mhz
TIM3CLK = 16Mhz
timer cnt clk = 16Mhz  ..
prescaler of timer = 0
OC pulse value = 16000000/50000.
this config doesnt work at all .  it just generated wave of ~122Hz .
can you please help to debug the issue ?
