Clk Configuration problem
Question asked by Mohamed GORRAB on Apr 10, 2018
Hi, the problem is not solved, below is the clock configuration,
configuration problem
Based on the figure above, I tried to use the different divisions /1, /8.. and the different clk (PPLCK, SYCLK, HSE...)  to obtain the correct frequency, but everytime, I have the some frequeny output that I showed on the scope,
HSI --> 16MHZ (correct value)
SYSCLK --> 32MHZ (wrong value != 10 MHZ)
PLLCLK --> 32MHZ (wrong value  != 10 MHZ)
I added some instructions on the code to show the frequency value, and that gives 32MHZ as shown on the pictures below
code
result1
result2
Anyone have a solution please!
Thanks in advance!
