Maximum cover window for VL53L1X/VL53L0X
Question asked by Diego Moreno on Mar 28, 2018
Latest reply on May 2, 2018 by john kvam
The previous proximity sensor VL53L0X has a application note (AN4907: VL53L0X ranging module cover window guidelines) that specifies the cover window thickness limits for different distances that can be measured.
I wonder if there is a similar document for the new VL53L1X, because so far I could not find any. I need to measure at least 1000mm for a cover window that is 3mm thick.
Is there is a way to measure the 1000mm with the 3mm cover window for the VL53L0X, that would be even better.
