Prescaler value is not updating.
Question asked by Shubhendu Banerjee on Mar 17, 2018
Latest reply on Mar 19, 2018 by Shubhendu Banerjee
Here is the code snippets-
/* My custom timer struct */
typedef struct TagPWMTimer
    TIM_TypeDef *TIMx;
    HAL_TIM_ActiveChannel Channel;
    uint32_t Prescaler;
    uint32_t Count_Periode;
    uint32_t Count_Pulse;
    TimerMode Timer_Mode;
    TimerSubMode Timer_Sub_Mode;
    PeripheralState Peripheral_State;
}PWMTimer, *pPWMTimer;
/* Struct initialization here */
SegmentPWMGenerator_Timer=*(TIM21);
    SegmentPWMGenerator.TIMx=SegmentPWMGenerator_Timer;
    SegmentPWMGenerator.Channel=LL_TIM_CHANNEL_CH1;
    SegmentPWMGenerator.Prescaler=16000;
    SegmentPWMGenerator.Count_Periode=0X9FFF;
    SegmentPWMGenerator.Count_Pulse=0x1FFF;
    SegmentPWMGenerator.Timer_Mode=PWM1;
    SegmentPWMGenerator.Timer_Sub_Mode=EdgeAlliened;
    PWM_Init(&SegmentPWMGenerator);
/* PWM_Init definition */
status PWM_Init(PWMTimer * pPWMTimer_n)
    status ReturnStatus=0;
    pPWMTimer_n->Peripheral_State=BUSY;
      /* Set the Prescaler value */
    pPWMTimer_n->TIMx->CR1=SETBIT(pPWMTimer_n->TIMx->CR1, UDIS);
    LL_TIM_SetPrescaler (pPWMTimer_n->TIMx, pPWMTimer_n->Prescaler);
    LL_TIM_EnableARRPreload(pPWMTimer_n->TIMx);
    LL_TIM_SetAutoReload(pPWMTimer_n->TIMx, pPWMTimer_n->Count_Periode);//__LL_TIM_CALC_ARR(16000000,LL_TIM_GetPrescaler (pPWMTimer_n->TIMx),20000));
    LL_TIM_SetCounterMode(pPWMTimer_n->TIMx, LL_TIM_COUNTERMODE_UP);
    ReturnStatus=Channel_Init(pPWMTimer_n);
    LL_TIM_EnableCounter(pPWMTimer_n->TIMx);
    LL_TIM_GenerateEvent_UPDATE(pPWMTimer_n->TIMx);
    pPWMTimer_n->Peripheral_State=READY;
    return ReturnStatus;
/* Channel_Init Definition */
status Channel_Init(PWMTimer * pPWMTimer_n)
    LL_TIM_EnableIT_UPDATE(pPWMTimer_n->TIMx);
    if(pPWMTimer_n->TIMx==TIM21)
        HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5,GPIO_PIN_SET);
        __HAL_RCC_TIM21_CLK_ENABLE();
        HAL_NVIC_SetPriority(TIM21_IRQn, 0, 0);
        HAL_NVIC_EnableIRQ(TIM21_IRQn);
        TIM21->DIER |= TIM_IT_UPDATE;
    if(GETBIT(pPWMTimer_n->TIMx->CR1, CEN)!=1)
        switch(pPWMTimer_n->Timer_Sub_Mode)
            case EdgeAlliened:
                break;
            case CenterAligned_1:
                break;
            case CenterAligned_2:
                break;
            case CenterAligned_3:
                break;
    else
        ReturnStatus= STATUS_INCOMPLETE;
    switch(pPWMTimer_n->Channel)
        case LL_TIM_CHANNEL_CH1:
            pPWMTimer_n->TIMx->CCR1=pPWMTimer_n->Count_Pulse;
            switch(pPWMTimer_n->Timer_Mode)
                case Freeze:
                    break;
                case UpCount:
                    break;
                case DownCount:
                    break;
                case CenterAligned:
                    break;
                case InputCapture:
                    break;
                case PWMInput:
                    break;
                case ForcedOutput:
                    break;
                case OutputCompare:
                    break;
                case PWM1:
                    LL_TIM_OC_SetMode(pPWMTimer_n->TIMx, LL_TIM_CHANNEL_CH1, LL_TIM_OCMODE_PWM1);
                    LL_TIM_OC_ConfigOutput(pPWMTimer_n->TIMx, LL_TIM_CHANNEL_CH1, LL_TIM_OCPOLARITY_HIGH);
                    LL_TIM_CC_EnableChannel(pPWMTimer_n->TIMx, LL_TIM_CHANNEL_CH1);
                    break;
                case PWM2:
                    break;
                case OnePulse:
                    break;
                case EncoderInterface:
                    break;
                default:
                    break;
            break;
        case 2:
            break;
        default:
            ReturnStatus=6;
            break;
