Magnetic field sensor - suggestion
Question asked by Jacek Pieczaba on Mar 12, 2018
Latest reply on Mar 15, 2018 by Jacek Pieczaba
I am planning to build a concept of level sensing system based on the magnetic field sensor ( ideally 3 axis ) which will be located on the bottom of the canister and flowing on the surface neodymium magnet. What Sensor you could suggest to be used for testing ( I am assume maybe the most sensitive and with digital front end baked-in in order to reduce noise to minimum ).
The test will help me to determine how far sensor and magnet could operate giving an reliable information, and also what other factors could affect the readings.
Thanks a lot in advnace
Jacek
