NUCLEO-H743ZI board LD39050PU33R
Question asked by Kevin Angus on Mar 10, 2018
Latest reply on Mar 11, 2018 by Kevin Angus
On the NUCLEO-H743ZI board the LD39050PU33R 3.3 volt LDO provides voltage but what is the Vd or Vdrop for the LD39050PU33R?
I found I can add 3.7 volt (18650 battery) to JP3 pin 3  : I can't use VBAT as it is wired to 3.3 volts.
Object, run board on battery!
Thanks...
