Error_Handler debugging
Question asked by David Pekin on Feb 27, 2018
Latest reply on Feb 27, 2018 by Clive One
The HAL code uses a Error_Handler() function which just spins forever in a tight loop.   I've seen comments about changing the call to report __FILE__ & __LINE__  which I may do.   But I thought setting a breakpoint in the Error_Handler() code would lead me to the caller and failure.   I'm using the IAR tools and when the breakpoint is hit, the call stack shows, main, Exception Frame, and Error_Handler.  This doesn't tell me what called the Error_Handler() function.
Does anyone know how to track down the caller using the IAR debugger?
Thanks!
