HAL_I2C_SlaveRxCpltCallback DMA Mode never called
Question asked by Brian Dahl on Feb 22, 2018
i use 2 Boards B-L475 IOT Board, connect via I2c Together.
I run on the Client a Simple Rx DMA Programm and on the Server a Simple Tx DMA Programm.
On the Slave were never called HAL_I2C_SlaveRxCpltCallback(), but when i stop the Debugger after transmitting, then are the message transmitted but not notified with the Interrupt.
Can anybody help me?
  * @file           : main.c
  * @brief          : Server
#include "main.h"
#include "stm32l4xx_hal.h"
/* USER CODE END Includes */
DFSDM_Channel_HandleTypeDef hdfsdm1_channel1;
I2C_HandleTypeDef hi2c2;
I2C_HandleTypeDef hi2c3;
DMA_HandleTypeDef hdma_i2c3_rx;
DMA_HandleTypeDef hdma_i2c3_tx;
QSPI_HandleTypeDef hqspi;
SPI_HandleTypeDef hspi3;
UART_HandleTypeDef huart1;
UART_HandleTypeDef huart3;
PCD_HandleTypeDef hpcd_USB_OTG_FS;
/* USER CODE BEGIN PV */
char cTxBuffer[14] = "Hi my name is";
char cRxBuffer[128];
/* USER CODE END PV */
static void MX_DMA_Init(void);
static void MX_DFSDM1_Init(void);
static void MX_I2C2_Init(void);
static void MX_QUADSPI_Init(void);
static void MX_SPI3_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_USART3_UART_Init(void);
static void MX_USB_OTG_FS_PCD_Init(void);
static void MX_I2C3_Init(void);
static void MX_NVIC_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval None
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_DFSDM1_Init();
  MX_I2C3_Init();
  /* Initialize interrupts */
  MX_NVIC_Init();
  /* USER CODE BEGIN 2 */
     HAL_I2C_Master_Transmit_DMA(&hi2c3, 19, (uint8_t*)cTxBuffer, sizeof(cTxBuffer));
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @retval None
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
    /**Configure LSE Drive Capability
  __HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW);
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE|RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSICalibrationValue = 0;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 40;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV7;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART3
                              |RCC_PERIPHCLK_I2C2|RCC_PERIPHCLK_I2C3
                              |RCC_PERIPHCLK_DFSDM1|RCC_PERIPHCLK_USB;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  PeriphClkInit.Usart3ClockSelection = RCC_USART3CLKSOURCE_PCLK1;
  PeriphClkInit.I2c2ClockSelection = RCC_I2C2CLKSOURCE_PCLK1;
  PeriphClkInit.I2c3ClockSelection = RCC_I2C3CLKSOURCE_PCLK1;
  PeriphClkInit.Dfsdm1ClockSelection = RCC_DFSDM1CLKSOURCE_PCLK;
  PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLLSAI1;
  PeriphClkInit.PLLSAI1.PLLSAI1Source = RCC_PLLSOURCE_MSI;
  PeriphClkInit.PLLSAI1.PLLSAI1M = 1;
  PeriphClkInit.PLLSAI1.PLLSAI1N = 24;
  PeriphClkInit.PLLSAI1.PLLSAI1P = RCC_PLLP_DIV7;
  PeriphClkInit.PLLSAI1.PLLSAI1Q = RCC_PLLQ_DIV2;
  PeriphClkInit.PLLSAI1.PLLSAI1R = RCC_PLLR_DIV2;
  PeriphClkInit.PLLSAI1.PLLSAI1ClockOut = RCC_PLLSAI1_48M2CLK;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    /**Configure the main internal regulator output voltage
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    /**Configure the Systick interrupt time
    /**Enable MSI Auto calibration
  HAL_RCCEx_EnableMSIPLLMode();
  * @brief NVIC Configuration.
  * @retval None
  /* DMA1_Channel2_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Channel2_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel2_IRQn);
  /* DMA1_Channel3_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Channel3_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel3_IRQn);
  /* I2C3_EV_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(I2C3_EV_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(I2C3_EV_IRQn);
  /* I2C3_ER_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(I2C3_ER_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(I2C3_ER_IRQn);
/* DFSDM1 init function */
  hdfsdm1_channel1.Instance = DFSDM1_Channel1;
  hdfsdm1_channel1.Init.OutputClock.Activation = ENABLE;
  hdfsdm1_channel1.Init.OutputClock.Selection = DFSDM_CHANNEL_OUTPUT_CLOCK_SYSTEM;
  hdfsdm1_channel1.Init.OutputClock.Divider = 2;
  hdfsdm1_channel1.Init.Input.Multiplexer = DFSDM_CHANNEL_EXTERNAL_INPUTS;
  hdfsdm1_channel1.Init.Input.DataPacking = DFSDM_CHANNEL_STANDARD_MODE;
  hdfsdm1_channel1.Init.Input.Pins = DFSDM_CHANNEL_FOLLOWING_CHANNEL_PINS;
  hdfsdm1_channel1.Init.SerialInterface.Type = DFSDM_CHANNEL_SPI_RISING;
  hdfsdm1_channel1.Init.SerialInterface.SpiClock = DFSDM_CHANNEL_SPI_CLOCK_INTERNAL;
  hdfsdm1_channel1.Init.Awd.FilterOrder = DFSDM_CHANNEL_FASTSINC_ORDER;
  hdfsdm1_channel1.Init.Awd.Oversampling = 1;
  hdfsdm1_channel1.Init.Offset = 0;
  hdfsdm1_channel1.Init.RightBitShift = 0x00;
  if (HAL_DFSDM_ChannelInit(&hdfsdm1_channel1) != HAL_OK)
/* I2C3 init function */
  hi2c3.Instance = I2C3;
  hi2c3.Init.Timing = 0x10909CEC;
  hi2c3.Init.OwnAddress1 = 0;
  hi2c3.Init.AddressingMode = I2C_ADDRESSINGMODE_10BIT;
  hi2c3.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c3.Init.OwnAddress2 = 0;
  hi2c3.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
  hi2c3.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c3.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c3) != HAL_OK)
    /**Configure Analogue filter
  if (HAL_I2CEx_ConfigAnalogFilter(&hi2c3, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
    /**Configure Digital filter
  if (HAL_I2CEx_ConfigDigitalFilter(&hi2c3, 0) != HAL_OK)
  * Enable DMA controller clock
  __HAL_RCC_DMA1_CLK_ENABLE();
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
     PC2   ------> ADCx_IN3
     PC3   ------> ADCx_IN4
     PA0   ------> UART4_TX
     PA1   ------> UART4_RX
     PA3   ------> S_TIM2_CH4
     PA4   ------> ADCx_IN9
     PA5   ------> SPI1_SCK
     PA6   ------> SPI1_MISO
     PA7   ------> SPI1_MOSI
     PC4   ------> ADCx_IN13
     PC5   ------> ADCx_IN14
     PB1   ------> ADCx_IN16
     PD1   ------> SPI2_SCK
     PD3   ------> USART2_CTS
     PD4   ------> USART2_RTS
     PD5   ------> USART2_TX
     PD6   ------> USART2_RX
     PB8   ------> I2C1_SCL
     PB9   ------> I2C1_SDA
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOE_CLK_ENABLE();
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOE, M24SR64_Y_RF_DISABLE_Pin|M24SR64_Y_GPO_Pin|ISM43362_RST_Pin|ISM43362_SPI3_CSN_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOA, ARD_D10_Pin|SPBTLE_RF_RST_Pin|ARD_D9_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOB, ARD_D8_Pin|ISM43362_BOOT0_Pin|ISM43362_WAKEUP_Pin|LED2_Pin
                          |SPSGRF_915_SDN_Pin|ARD_D5_Pin|SPSGRF_915_SPI3_CSN_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOD, USB_OTG_FS_PWR_EN_Pin|SPBTLE_RF_SPI3_CSN_Pin|PMOD_RESET_Pin|STSAFE_A100_RESET_Pin, GPIO_PIN_RESET);
  HAL_GPIO_WritePin(GPIOC, VL53L0X_XSHUT_Pin|LED3_WIFI__LED4_BLE_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pins : M24SR64_Y_RF_DISABLE_Pin M24SR64_Y_GPO_Pin ISM43362_RST_Pin ISM43362_SPI3_CSN_Pin */
  GPIO_InitStruct.Pin = M24SR64_Y_RF_DISABLE_Pin|M24SR64_Y_GPO_Pin|ISM43362_RST_Pin|ISM43362_SPI3_CSN_Pin;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  /*Configure GPIO pins : USB_OTG_FS_OVRCR_EXTI3_Pin SPSGRF_915_GPIO3_EXTI5_Pin SPBTLE_RF_IRQ_EXTI6_Pin ISM43362_DRDY_EXTI1_Pin */
  GPIO_InitStruct.Pin = USB_OTG_FS_OVRCR_EXTI3_Pin|SPSGRF_915_GPIO3_EXTI5_Pin|SPBTLE_RF_IRQ_EXTI6_Pin|ISM43362_DRDY_EXTI1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
  /*Configure GPIO pin : BUTTON_EXTI13_Pin */
  GPIO_InitStruct.Pin = BUTTON_EXTI13_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
  HAL_GPIO_Init(BUTTON_EXTI13_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : ARD_A3_Pin ARD_A2_Pin ARD_A1_Pin ARD_A0_Pin */
  GPIO_InitStruct.Pin = ARD_A3_Pin|ARD_A2_Pin|ARD_A1_Pin|ARD_A0_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_ANALOG_ADC_CONTROL;
  /*Configure GPIO pins : ARD_D1_Pin ARD_D0_Pin */
  GPIO_InitStruct.Pin = ARD_D1_Pin|ARD_D0_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF8_UART4;
  /*Configure GPIO pins : ARD_D10_Pin SPBTLE_RF_RST_Pin ARD_D9_Pin */
  GPIO_InitStruct.Pin = ARD_D10_Pin|SPBTLE_RF_RST_Pin|ARD_D9_Pin;
  /*Configure GPIO pin : ARD_D4_Pin */
  GPIO_InitStruct.Pin = ARD_D4_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF1_TIM2;
  HAL_GPIO_Init(ARD_D4_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : ARD_D7_Pin */
  GPIO_InitStruct.Pin = ARD_D7_Pin;
  HAL_GPIO_Init(ARD_D7_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : ARD_D13_Pin ARD_D12_Pin ARD_D11_Pin */
  GPIO_InitStruct.Pin = ARD_D13_Pin|ARD_D12_Pin|ARD_D11_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI1;
  /*Configure GPIO pin : ARD_D3_Pin */
  GPIO_InitStruct.Pin = ARD_D3_Pin;
  HAL_GPIO_Init(ARD_D3_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : ARD_D6_Pin */
  GPIO_InitStruct.Pin = ARD_D6_Pin;
  HAL_GPIO_Init(ARD_D6_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : ARD_D8_Pin ISM43362_BOOT0_Pin ISM43362_WAKEUP_Pin LED2_Pin
                           SPSGRF_915_SDN_Pin ARD_D5_Pin SPSGRF_915_SPI3_CSN_Pin */
  GPIO_InitStruct.Pin = ARD_D8_Pin|ISM43362_BOOT0_Pin|ISM43362_WAKEUP_Pin|LED2_Pin
                          |SPSGRF_915_SDN_Pin|ARD_D5_Pin|SPSGRF_915_SPI3_CSN_Pin;
  /*Configure GPIO pins : LPS22HB_INT_DRDY_EXTI0_Pin LSM6DSL_INT1_EXTI11_Pin ARD_D2_Pin HTS221_DRDY_EXTI15_Pin
                           PMOD_IRQ_EXTI12_Pin */
  GPIO_InitStruct.Pin = LPS22HB_INT_DRDY_EXTI0_Pin|LSM6DSL_INT1_EXTI11_Pin|ARD_D2_Pin|HTS221_DRDY_EXTI15_Pin
                          |PMOD_IRQ_EXTI12_Pin;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  /*Configure GPIO pins : USB_OTG_FS_PWR_EN_Pin SPBTLE_RF_SPI3_CSN_Pin PMOD_RESET_Pin STSAFE_A100_RESET_Pin */
  GPIO_InitStruct.Pin = USB_OTG_FS_PWR_EN_Pin|SPBTLE_RF_SPI3_CSN_Pin|PMOD_RESET_Pin|STSAFE_A100_RESET_Pin;
  /*Configure GPIO pins : VL53L0X_XSHUT_Pin LED3_WIFI__LED4_BLE_Pin */
  GPIO_InitStruct.Pin = VL53L0X_XSHUT_Pin|LED3_WIFI__LED4_BLE_Pin;
  /*Configure GPIO pins : VL53L0X_GPIO1_EXTI7_Pin LSM3MDL_DRDY_EXTI8_Pin */
  GPIO_InitStruct.Pin = VL53L0X_GPIO1_EXTI7_Pin|LSM3MDL_DRDY_EXTI8_Pin;
  /*Configure GPIO pin : PMOD_SPI2_SCK_Pin */
  GPIO_InitStruct.Pin = PMOD_SPI2_SCK_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
  HAL_GPIO_Init(PMOD_SPI2_SCK_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pins : PMOD_UART2_CTS_Pin PMOD_UART2_RTS_Pin PMOD_UART2_TX_Pin PMOD_UART2_RX_Pin */
  GPIO_InitStruct.Pin = PMOD_UART2_CTS_Pin|PMOD_UART2_RTS_Pin|PMOD_UART2_TX_Pin|PMOD_UART2_RX_Pin;
  GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
  /*Configure GPIO pins : ARD_D15_Pin ARD_D14_Pin */
  GPIO_InitStruct.Pin = ARD_D15_Pin|ARD_D14_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
  /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI9_5_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI9_5_IRQn);
  HAL_NVIC_SetPriority(EXTI15_10_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
/* USER CODE BEGIN 4 */
void HAL_I2C_MasterRxCpltCallback(I2C_HandleTypeDef *I2cHandle)
     int i = 0;
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  file: The file name as string.
  * @param  line: The line in file as a number.
  * @retval None
void _Error_Handler(char *file, int line)
  while(1)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* USER CODE BEGIN 6 */
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
  * @file           : main.c
  * @brief          : Client
#include "main.h"
char cTxBuffer[14] = "Hugo";
  * @retval None
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_DFSDM1_Init();
  MX_I2C3_Init();
  MX_NVIC_Init();
     HAL_I2C_Slave_Receive_DMA(&hi2c3, (uint8_t*) cRxBuffer, sizeof(cRxBuffer));
  /* Infinite loop */
  while (1)
  * @retval None
  * @retval None
  hi2c3.Init.OwnAddress1 = 19;
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
int Transfered = 0;
void HAL_I2C_SlaveRxCpltCallback(I2C_HandleTypeDef *I2cHandle)
     Transfered = 255;
  * @retval None
  while(1)
  * @retval None
