CubeMX V4.24 with FatFS R0.12c problem to work with SD card when FreeRTOS is present
Question asked by Evgeniy Vasyliev on Feb 21, 2018
Latest reply on Feb 23, 2018 by Evgeniy Vasyliev
I am trying to use the latest CubeMX V4.24 with FatFS R0.12c, I am using FreeRTOS in my project. The SD card is connected using SDIO 4-bits wide bus. The MCU is STM32F427. HAL driver is V1.19.
The problem is that f_mount function is never working. Seems that a response from queue never comes in function SD_read from sd_diskio.c file:
event = osMessageGet(SDQueueID, SD_TIMEOUT);
I was able to make f_mount work OK by applying suggestions described in this post, which refers to CubeMX V4.23: STM32Cube_FW_F4_V1.18.0 + SDIO + FATFS R0.12c doesn't work, however now creation of a file does not work.
Can you suggest anything?
P.S. I know that when there is no FreeRTOS present operation with SD card is working well as provided in examples of CubeMX.
