CubeMX bug report: error in generated stm32f2xx_hal_msp.c
Question asked by Maciej Musiał on Feb 4, 2018
Latest reply on Feb 12, 2018 by Jeanne Joly
   Hello!
  I found a problem with initialization code generated for TIM2 when you select Clock source as ETR2. The bug is with pin initialization for alternate function: GPIO_InitStruct.Alternate is not set to any value (let alone the desired one):
Inside function HAL_TIM_Base_MspInit:
/**TIM2 GPIO Configuration
    PA0-WKUP     ------> TIM2_ETR
    GPIO_InitStruct.Pin = GPIO_PIN_0;
The version of CubeMX is 4.24.0
The problem is only with TIM2, all other timers generate proper code.
Maciej
