SPWF04SA  ,can not send message just receive
Question asked by maor.yaniv.001 on Jan 22, 2018
Latest reply on Jan 22, 2018 by Elio Cometti
hello ,
the WiFi is freeze whe:n sending a message ,
receiving is working very  good ,writing fails  i used Uart
please advice  :
+WIND:0:Console active
+WIND:3:Watchdog Running:20
+WIND:32:WiFi Hardware Started
+WIND:19:WiFi Join:3C:1E:04:03:B9:46
+WIND:25:WiFi Association successful:yaniv
+WIND:51:WPA Handshake Complete
+WIND:24:WiFi Up:0:10.0.0.4
+WIND:24:WiFi Up::fe80:0:0:0:280:e1ff:febd:d122
+WIND:84:NTP Server delivery:2018.1.22:1:13.40.9
AT+S.SOCKON=10.0.0.2,32000,,t
AT-S.On:10.0.0.2:0
AT-S.OK
AT+S.SOCKW=0,11<CR>
then i write hello word <cr>
and then it freeze
this is the configuration status
AT+S.STS
AT-S.List
AT-S.Var:build=170216-fd39c59-SPWF04S
AT-S.Var:fw_version=1.0.0
AT-S.Var:boot_version=1.0
AT-S.Var:var_version=1
AT-S.Var:free_heap=69896
AT-S.Var:min_heap=69072
AT-S.Var:system_time=635
AT-S.Var:system_uptime=635
AT-S.Var:system_sleeptime=0
AT-S.Var:reset_reason=0
AT-S.Var:startup=0
AT-S.Var:random_number=1753830384
AT-S.Var:gpio_enable=0x0000
AT-S.Var:app_fs=1
AT-S.Var:user_fs=0
AT-S.Var:extvol_fs=0
AT-S.Var:nv_power_cycles=32
AT-S.Var:nv_wdog_resets=0
AT-S.Var:nv_reset_cycles=101
AT-S.Var:wifi_state=10
AT-S.Var:wifi_own_macaddr=00:80:E1:BD:D1:22
AT-S.Var:wifi_bssid=3C:1E:04:03:B9:46
AT-S.Var:wifi_aid=2
AT-S.Var:wifi_channelnum=11
AT-S.Var:wifi_sup_rate_mask=0x003FFFCF
AT-S.Var:wifi_bas_rate_mask=0x0000000F
AT-S.Var:wifi_chan_activity=0x00001FFF
AT-S.Var:wifi_max_tx_power=18
AT-S.Var:wifi_gf_mode=0
AT-S.Var:wifi_reg_country=IL
AT-S.Var:wifi_dtim_period=1
AT-S.Var:wifi_num_assoc=0
AT-S.Var:ip_from_AutoIP=0
AT-S.Var:ip_ipaddr=10.0.0.4
AT-S.Var:ip_netmask=255.255.255.0
AT-S.Var:ip_gw=10.0.0.138
AT-S.Var:ip_dns1=10.0.0.138
AT-S.Var:ip_dns2=0.0.0.0
AT-S.Var:ip_linklocal=fe80:0:0:0:280:e1ff:febd:d122
AT-S.Var:ip_local=0:0:0:0:0:0:0:0
AT-S.Var:ip_dns1v6=0:0:0:0:0:0:0:0
AT-S.Var:ip_dns2v6=0:0:0:0:0:0:0:0
AT-S.OK
