stpm10 Datasheet current channel calibration register bad description
Question asked by Alexander on Jan 18, 2018
Latest reply on Jan 31, 2018 by Alexander
We are working on power consumption measurement implementing the stpm10 with a Steval IPE017V1. There is some informations missing in the datasheet at config register description about the CHP register. It should be a 8 bits register. 16 bit are assigned for it and the corresponding description is about some other unknown register: CHS
I suppose that this register is for primary and secondary calibration, can someone confirm it and tell us to which of the channel the first and second byte are coresponding ?
Also can you give some precision on where are the LSB and MSB. Do the LSB start at low adress value ?
Thank you,
Alexander
