Issues with STM32L4 ADC (Full Scale Reading)
Question asked by bujak.daniel on Jan 18, 2018
Latest reply on Jan 22, 2018 by bujak.daniel
I'm trying to setup ADC reads on a STM32L431 and am having issues. I was able to get things working on the STM32L476-based Nucleo board, but can't get it working on my custom board based on the STM32L431VC. I've tried setting things up using CubeMx and also by copying the sample code from the Nucleo examples, in polling or interrupt mode, but nothing is working.
I'm entering the HAL_ADC_ConvCpltCallback() function but get a reading of 0xFFF regardless of what the actual level of the input is. I'm not seeing any errors being reported.
Here's my main.c (mostly as generated by cubeMx) and the full project is attached.
  * File Name          : main.c
  * Description        : Main program body
  ** This notice applies to any and all portions of this file
  * that are not between comment pairs USER CODE BEGIN and
  * USER CODE END. Other portions of this file, whether
  * inserted by the user or by software development tools
  * are owned by their respective copyright owners.
  * COPYRIGHT(c) 2018 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "main.h"
#include "stm32l4xx_hal.h"
ADC_HandleTypeDef hadc1;
/* Variable used to get converted value */
__IO uint16_t uhADCxConvertedValue = 0;
uint8_t adc_cnt = 0;
static void MX_ADC1_Init(void);
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
    uhADCxConvertedValue = HAL_ADC_GetValue(hadc);
void ADC_Capture(void)
  HAL_StatusTypeDef rc = HAL_ADC_Start_IT(&hadc1);
  if (rc == HAL_BUSY)
    printf("ADC BUSY!\r\n");
  else if (rc != HAL_OK)
    /* Start Conversation Error */
    Error_Handler();
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_ADC1_Init();
  /* Run the ADC calibration in single-ended mode */
  if (HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED) != HAL_OK)
    /* Calibration Error */
    Error_Handler();
  /*##-3- Start the conversion process #######################################*/
  if (HAL_ADC_Start_IT(&hadc1) != HAL_OK)
    Error_Handler();
  /* Infinite loop */
  while (1)
    HAL_Delay(1000);
    ADC_Capture();
/** System Clock Configuration
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
  /**Initializes the CPU, AHB and APB busses clocks */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSICalibrationValue = 0;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
  PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLLSAI1;
  PeriphClkInit.PLLSAI1.PLLSAI1Source = RCC_PLLSOURCE_MSI;
  PeriphClkInit.PLLSAI1.PLLSAI1M = 1;
  PeriphClkInit.PLLSAI1.PLLSAI1N = 16;
  PeriphClkInit.PLLSAI1.PLLSAI1P = RCC_PLLP_DIV7;
  PeriphClkInit.PLLSAI1.PLLSAI1Q = RCC_PLLQ_DIV2;
  PeriphClkInit.PLLSAI1.PLLSAI1R = RCC_PLLR_DIV2;
  PeriphClkInit.PLLSAI1.PLLSAI1ClockOut = RCC_PLLSAI1_ADC1CLK;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
  /**Configure the main internal regulator output voltage */
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
  /**Configure the Systick interrupt time */
  /**Configure the Systick */
/* ADC1 init function */
  ADC_ChannelConfTypeDef sConfig;
  /**Common config */
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler        = ADC_CLOCK_ASYNC_DIV1;
  hadc1.Init.Resolution            = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign             = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode          = ADC_SCAN_DISABLE;
  hadc1.Init.EOCSelection          = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait      = DISABLE;
  hadc1.Init.ContinuousConvMode    = DISABLE;
  hadc1.Init.NbrOfConversion       = 1;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.NbrOfDiscConversion   = 1;
  hadc1.Init.ExternalTrigConv      = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge  = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.Overrun               = ADC_OVR_DATA_PRESERVED;
  hadc1.Init.OversamplingMode      = DISABLE;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
  /**Configure Regular Channel */
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_640CYCLES_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
/** Pinout Configuration
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /* Enable Temperature Sensor */
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_12, GPIO_PIN_SET);
  GPIO_InitStruct.Pin = GPIO_PIN_12;     /* Temperature Enable */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
void _Error_Handler(char * file, int line)
  while(1)
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
