Customer is having issue with LIS2MDL offset cancellation. Can you help?
Question asked by minnelli.mike.001 on Jan 16, 2018
Latest reply on Jan 18, 2018 by Miroslav B
   Here is their initialization code:
    i2c_LIS2MDL_Read_8Bit(LIS2MDL_WHO_AM_I, &b);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_X_REG_L,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_X_REG_H,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Y_REG_L,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Y_REG_H,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Z_REG_L,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_OFFSET_Z_REG_H,0x00);
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_CFG_REG_A,0b10001100);// temp comp, continuous 100hz data rate
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_CFG_REG_B,0b00000010);// offset cancellation enabled
    i2c_LIS2MDL_Write_8Bit(LIS2MDL_CFG_REG_C,0b00010000);// block data
Does anything need to be modified or added?  Thank you.
