STM32L452 QUAD SPI - wrong address on bus
Question asked by Alex Mach on Jan 16, 2018
I use STM32L452 QUAd SPI for communicate with Winbond w25n01g NAND Flash.
My init code is
page = 0x30;
  /* Initialize the read command */
  sCommand.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
  sCommand.Instruction       = PAGE_DATA_READ_CMD;
  sCommand.AddressMode       = QSPI_ADDRESS_1_LINES;
  sCommand.AddressSize       = QSPI_ADDRESS_16_BITS;
  sCommand.Address           = page;
  sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
  sCommand.DataMode          = QSPI_DATA_NONE;
  sCommand.DummyCycles       = 8;
  sCommand.DdrMode           = QSPI_DDR_MODE_DISABLE;
  sCommand.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
  sCommand.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
  /* Configure the command */
  if (HAL_QSPI_Command(&QSPIHandle, &sCommand, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
    return QSPI_ERROR;
but on bus I see the address byte 0x30  is hi byte of 16-bit address and lo byte is 0xFF. So, how can I fix this?
Thanks,
Alex
