Cubemx 4.4.0 rtc bug
Question asked by toth.janos on Oct 17, 2014
Latest reply on Nov 17, 2014 by toth.janos
Hello everybody!
I found a bug with the new cubemx and rtc clock code generation.
So I set te RTC paramters at cubemx, the first what I see that the sync predivider limited to max 255, but this is a 16bit variable in the mikrocontroller.
So second bug, that the generated code:
  * File Name          : RTC.c
  * Date               : 17/10/2014 21:20:24
  * Description        : This file provides code for the configuration
  *                      of the RTC instances.
  * COPYRIGHT(c) 2014 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "rtc.h"
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
RTC_HandleTypeDef hrtc;
/* RTC init function */
void MX_RTC_Init(void)
  RTC_TimeTypeDef sTime;
  RTC_DateTypeDef sDate;
    /**Initialize RTC and set the Time and Date
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  sTime.Hours = 0;
  sTime.Minutes = 0;
  sTime.Seconds = 0;
  sTime.SubSeconds = 0;
  sTime.TimeFormat = RTC_HOURFORMAT12_AM;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  sDate.WeekDay = RTC_WEEKDAY_MONDAY;
  sDate.Month = RTC_MONTH_JANUARY;
  sDate.Date = 1;
  sDate.Year = 0;
    /**Enable the WakeUp
void HAL_RTC_MspInit(RTC_HandleTypeDef* hrtc)
  if(hrtc->Instance==RTC)
  /* USER CODE BEGIN RTC_MspInit 0 */
  /* USER CODE END RTC_MspInit 0 */
    /* Peripheral interrupt init*/
    HAL_NVIC_SetPriority(RTC_WKUP_IRQn, 1, 0);
    HAL_NVIC_EnableIRQ(RTC_WKUP_IRQn);
  /* USER CODE BEGIN RTC_MspInit 1 */
  /* USER CODE END RTC_MspInit 1 */
void HAL_RTC_MspDeInit(RTC_HandleTypeDef* hrtc)
  /* USER CODE BEGIN RTC_MspDeInit 0 */
  /* USER CODE END RTC_MspDeInit 0 */
    /* Peripheral interrupt Deinit*/
    HAL_NVIC_DisableIRQ(RTC_WKUP_IRQn);
  /* USER CODE BEGIN RTC_MspDeInit 1 */
  /* USER CODE END RTC_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
What we see, that te MX_RTC_Init function doesn't do anything. What can I do this sutiation?
I use stm32f407ig controller and the latest cubemx softwares.
