DMA Write Issues with STM32L4R9-DISCO SDMMC
Question asked by Clive One on Jan 5, 2018
Latest reply on May 17, 2018 by Imen D
The HAL_SD_ErrorCallback() is called EVERY time a one sector DMA Write is used
ie
SD_state = BSP_SD_WriteBlocks_DMA((uint32_t *)buff, sector, count); // With count == 1
void SDMMC1_IRQHandler(void)
HAL_SD_IRQHandler(&hsd_discovery); // Calls the handler
Here is the offending code in STM32L4xx_hal_sd.c, errorstate is 4 CMD_RSP_TIMEOUT
void HAL_SD_IRQHandler(SD_HandleTypeDef *hsd)
else if((hsd->Context & SD_CONTEXT_DMA) != RESET)
#if defined(STM32L4R5xx) || defined(STM32L4R7xx) || defined(STM32L4R9xx) || defined(STM32L4S5xx) || defined(STM32L4S7xx) || defined(STM32L4S9xx)
hsd->Instance->DLEN = 0;
hsd->Instance->DCTRL = 0;
hsd->Instance->IDMACTRL = SDMMC_DISABLE_IDMA;
/* Stop Transfer for Write Single/Multi blocks or Read Multi blocks */
if((hsd->Context & SD_CONTEXT_READ_SINGLE_BLOCK) == RESET)
errorstate = SDMMC_CmdStopTransfer(hsd->Instance);
if(errorstate != HAL_SD_ERROR_NONE)
hsd->ErrorCode |= errorstate;
HAL_SD_ErrorCallback(hsd);
It ends up here, and if I call Error_Handler(), basically GAME OVER
* @brief SDMMC error callback
* @param None
* @retval None
void HAL_SD_ErrorCallback(SD_HandleTypeDef *hsd)
puts("HAL_SD_ErrorCallback");
Getting 10.1 MBps Write Speeds, and 12.2 Read Speeds in current testing
