Big binary file, after moving code to different memory regions.
Question asked by ChrisH on Dec 6, 2017
Latest reply on Dec 9, 2017 by Clive One
Hi, after I moved my .bss and .data sections to SRAM2 on L476 my binary file blows into 400mb I know this question was raised here before but I still don't understand in my example why is this happening in this case. In my case, I place all the buffers and heap and stack in SRAM1 so, in reality, this is all uninitialized data which is later initialized to 0 in startup code. Why is it referenced anyway in a binary file? Also if I define sections like so placing them in:
RAM AT>FLASH
code links into small binary, but I guess it's not allowed since this is reserved for variables initialised with constant data from flash.
**  File        : LinkerScript.ld
**  Abstract    : Linker script for STM32L476RGTx Device with
**                1024KByte FLASH, 96KByte RAM
**                Set heap size, stack size and stack location according
**                to application requirements.
**                Set memory bank area and size if external memory is used.
**  Target      : STMicroelectronics STM32
**  Distribution: The file is distributed as is, without any warranty
**                of any kind.
** @attention
** <h2><center>&copy; COPYRIGHT(c) 2014 Ac6</center></h2>
** Redistribution and use in source and binary forms, with or without modification,
** are permitted provided that the following conditions are met:
**   1. Redistributions of source code must retain the above copyright notice,
**      this list of conditions and the following disclaimer.
**   2. Redistributions in binary form must reproduce the above copyright notice,
**      this list of conditions and the following disclaimer in the documentation
**      and/or other materials provided with the distribution.
**   3. Neither the name of Ac6 nor the names of its contributors
**      may be used to endorse or promote products derived from this software
**      without specific prior written permission.
** THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
** AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
** IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
** DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
** FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
** DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
** SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
** CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
** OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
** OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = 0x20018000;    /* end of RAM */
/* Generate a link error if heap and stack don't fit into RAM */
_Min_Heap_Size = 0x200;      /* required amount of heap  */
_Min_Stack_Size = 0x400; /* required amount of stack */
/* Specify the memory areas */
MEMORY
RAM (xrw)           : ORIGIN = 0x20000000,      LENGTH = 96K
RAM2BLVAR (xrw)     : ORIGIN = 0x10000000,      LENGTH = 0x20
RAM2 (xrw)           : ORIGIN = 0x10000020,      LENGTH = 0x7FE0
FLASH (rx)           : ORIGIN = 0x8000000,      LENGTH = 1020K
VERSION(rx)          : ORIGIN = 0x808F000,     LENGTH = 2K
CONFIG (xrw)          : ORIGIN = 0x808F800,      LENGTH = 2K
/* Define output sections */
SECTIONS
  /* The startup code goes first into FLASH */
  .isr_vector :
    . = ALIGN(8);
    KEEP(*(.isr_vector)) /* Startup code */
    . = ALIGN(8);
  } >FLASH
  /* The program code and other data goes into FLASH */
  .text :
    . = ALIGN(8);
    *(.text)           /* .text sections (code) */
    *(.text*)          /* .text* sections (code) */
    *(.glue_7)         /* glue arm to thumb code */
    *(.glue_7t)        /* glue thumb to arm code */
    *(.eh_frame)
    KEEP (*(.init))
    KEEP (*(.fini))
    . = ALIGN(8);
    _etext = .;        /* define a global symbols at end of code */
  } >FLASH
  /* Constant data goes into FLASH */
  .rodata :
    . = ALIGN(8);
    *(.rodata)         /* .rodata sections (constants, strings, etc.) */
    *(.rodata*)        /* .rodata* sections (constants, strings, etc.) */
    . = ALIGN(8);
  } >FLASH
  .ARM.extab   :
  . = ALIGN(8);
  *(.ARM.extab* .gnu.linkonce.armextab.*)
  . = ALIGN(8);
  } >FLASH
  .ARM : {
     . = ALIGN(8);
    __exidx_start = .;
    *(.ARM.exidx*)
    __exidx_end = .;
     . = ALIGN(8);
  } >FLASH
  .preinit_array     :
     . = ALIGN(8);
    PROVIDE_HIDDEN (__preinit_array_start = .);
    KEEP (*(.preinit_array*))
    PROVIDE_HIDDEN (__preinit_array_end = .);
     . = ALIGN(8);
  } >FLASH
  .init_array :
     . = ALIGN(8);
    PROVIDE_HIDDEN (__init_array_start = .);
    KEEP (*(SORT(.init_array.*)))
    KEEP (*(.init_array*))
    PROVIDE_HIDDEN (__init_array_end = .);
     . = ALIGN(8);
  } >FLASH
  .fini_array :
     . = ALIGN(8);
    PROVIDE_HIDDEN (__fini_array_start = .);
    KEEP (*(SORT(.fini_array.*)))
    KEEP (*(.fini_array*))
    PROVIDE_HIDDEN (__fini_array_end = .);
     . = ALIGN(8);
  } >FLASH
  /* placing my named section at given address: */
  .verSection :
    KEEP(*(.verSection)) /* keep my variable even if not referenced */
  } > VERSION
  /* used by the startup to initialize data */
  _sidata = LOADADDR(.data);
  /* Initialized data sections goes into RAM, load LMA copy after code */
  .data :
    . = ALIGN(8);
    _sdata = .;        /* create a global symbol at data start */
    *(.data)           /* .data sections */
    *(.data*)          /* .data* sections */
    . = ALIGN(8);
    _edata = .;        /* define a global symbol at data end */
  } >RAM2 AT> FLASH
  /* Uninitialized data section */
  . = ALIGN(4);
  .bss :
    /* This is used by the startup in order to initialize the .bss secion */
    _sbss = .;         /* define a global symbol at bss start */
    __bss_start__ = _sbss;
    *(.bss)
    *(.bss*)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;         /* define a global symbol at bss end */
    __bss_end__ = _ebss;
  } >RAM2
   /* RTOS Heap goes into RAM */
  .rtosHeap :
       . = ALIGN(4);
       _srtosHeap = .;
       __rtosHeap_start__ = _srtosHeap;
       *(.rtosHeap)
       *(.rtosHeap*)
       . = ALIGN(4);
       _ertosHeap = .;
       __rtosHeap_end__ = _ertosHeap;
  } >RAM
  .ramSection :
       . = ALIGN(4);
       _sramSection = .;
       __ramSection_start__ = _sramSection;
       *(.ramSection)
       *(.ramSection*)
       . = ALIGN(4);
       _eramSection = .;
       __ramSection_end__ = _eramSection;
  } >RAM
  /* User_heap_stack section, used to check that there is enough RAM left */
  ._user_heap_stack :
    . = ALIGN(8);
    PROVIDE ( end = . );
    PROVIDE ( _end = . );
    . = . + _Min_Heap_Size;
    . = . + _Min_Stack_Size;
    . = ALIGN(8);
  } >RAM
  /* Remove information from the standard libraries */
  /DISCARD/ :
    libc.a ( * )
    libm.a ( * )
    libgcc.a ( * )
  .ARM.attributes 0 : { *(.ARM.attributes) }
