f_write bug - report
Question asked by piet t on Dec 2, 2017
Latest reply on Dec 28, 2017 by Andrew Sund
Hey everyone,
I'm not sure if this has been reported yet, although I found two more bugs in the HAL stm32f7 libraries(v1.8.0) generated by cube.
When trying to write to a file using the f_write the system would exit with a FR_DISK_ERR which is weird as f_open passes and I can see the created file. I started debugging and the issue seemed to be in the move_window function specifically with the disk_read and disk_write. The issue was that it passes once but fails the second time and hence returns the FR_DISK_ERR .
Upon further debugging I found that HAL_SD_ReadBlocks_DMA and HAL_SD_WriteBlocks_DMA never resets the SDcard states after setting it to  hsd->State = HAL_SD_STATE_BUSY;.
therefore the check fails(in bold).
HAL_StatusTypeDef HAL_SD_WriteBlocks_DMA(SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
  SDMMC_DataInitTypeDef config;
  uint32_t errorstate = HAL_SD_ERROR_NONE;
  if(NULL == pData)
    hsd->ErrorCode |= HAL_SD_ERROR_PARAM;
    return HAL_ERROR;
  if(hsd->State == HAL_SD_STATE_READY)
    hsd->ErrorCode = HAL_DMA_ERROR_NONE;
    if((BlockAdd + NumberOfBlocks) > (hsd->SdCard.LogBlockNbr))
      hsd->ErrorCode |= HAL_SD_ERROR_ADDR_OUT_OF_RANGE;
      return HAL_ERROR;
    /* Initialize data control register */
    hsd->Instance->DCTRL = 0U;
    /* Enable SD Error interrupts */
    __HAL_SD_ENABLE_IT(hsd, (SDMMC_IT_DCRCFAIL | SDMMC_IT_DTIMEOUT | SDMMC_IT_TXUNDERR));
    /* Set the DMA transfer complete callback */
    hsd->hdmatx->XferCpltCallback = SD_DMATransmitCplt;
    /* Set the DMA error callback */
    hsd->hdmatx->XferErrorCallback = SD_DMAError;
    /* Set the DMA Abort callback */
    hsd->hdmatx->XferAbortCallback = NULL;
    if(hsd->SdCard.CardType != CARD_SDHC_SDXC)
      BlockAdd *= 512U;
    /* Set Block Size for Card */
    errorstate = SDMMC_CmdBlockLength(hsd->Instance, BLOCKSIZE);
    if(errorstate != HAL_SD_ERROR_NONE)
      /* Clear all the static flags */
      __HAL_SD_CLEAR_FLAG(hsd, SDMMC_STATIC_FLAGS);
      hsd->ErrorCode |= errorstate;
      hsd->State = HAL_SD_STATE_READY;
      return HAL_ERROR;
    /* Write Blocks in Polling mode */
    if(NumberOfBlocks > 1U)
      hsd->Context = (SD_CONTEXT_WRITE_MULTIPLE_BLOCK | SD_CONTEXT_DMA);
      /* Write Multi Block command */
      errorstate = SDMMC_CmdWriteMultiBlock(hsd->Instance, BlockAdd);
    else
      hsd->Context = (SD_CONTEXT_WRITE_SINGLE_BLOCK | SD_CONTEXT_DMA);
      /* Write Single Block command */
      errorstate = SDMMC_CmdWriteSingleBlock(hsd->Instance, BlockAdd);
      return HAL_ERROR;
    /* Enable SDMMC DMA transfer */
    __HAL_SD_DMA_ENABLE(hsd);
    /* Enable the DMA Channel */
    HAL_DMA_Start_IT(hsd->hdmatx, (uint32_t)pData, (uint32_t)&hsd->Instance->FIFO, (uint32_t)(BLOCKSIZE * NumberOfBlocks)/4);
    /* Configure the SD DPSM (Data Path State Machine) */
    config.DataTimeOut   = SDMMC_DATATIMEOUT;
    config.DataLength    = BLOCKSIZE * NumberOfBlocks;
    config.DataBlockSize = SDMMC_DATABLOCK_SIZE_512B;
    config.TransferDir   = SDMMC_TRANSFER_DIR_TO_CARD;
    config.TransferMode  = SDMMC_TRANSFER_MODE_BLOCK;
    config.DPSM          = SDMMC_DPSM_ENABLE;
    SDMMC_ConfigData(hsd->Instance, &config);
      return HAL_OK;
  else
    return HAL_BUSY;
To fix this you can refer to the HAL_SD_WriteBlocks or corresponding read blocks function and change the DMA code as follows(see bold):
HAL_StatusTypeDef HAL_SD_ReadBlocks_DMA(SD_HandleTypeDef *hsd, uint8_t *pData, uint32_t BlockAdd, uint32_t NumberOfBlocks)
  if(NULL == pData)
    return HAL_ERROR;
      return HAL_ERROR;
    __HAL_SD_ENABLE_IT(hsd, (SDMMC_IT_DCRCFAIL | SDMMC_IT_DTIMEOUT | SDMMC_IT_RXOVERR | SDMMC_IT_DATAEND));
    hsd->hdmarx->XferCpltCallback = SD_DMAReceiveCplt;
    hsd->hdmarx->XferErrorCallback = SD_DMAError;
    hsd->hdmarx->XferAbortCallback = NULL;
    HAL_DMA_Start_IT(hsd->hdmarx, (uint32_t)&hsd->Instance->FIFO, (uint32_t)pData, (uint32_t)(BLOCKSIZE * NumberOfBlocks)/4);
    /* Enable SD DMA transfer */
      BlockAdd *= 512U;
    config.TransferDir   = SDMMC_TRANSFER_DIR_TO_SDMMC;
      return HAL_ERROR;
    /* Read Blocks in DMA mode */
      hsd->Context = (SD_CONTEXT_READ_MULTIPLE_BLOCK | SD_CONTEXT_DMA);
      /* Read Multi Block command */
      errorstate = SDMMC_CmdReadMultiBlock(hsd->Instance, BlockAdd);
    else
      hsd->Context = (SD_CONTEXT_READ_SINGLE_BLOCK | SD_CONTEXT_DMA);
      /* Read Single Block command */
      errorstate = SDMMC_CmdReadSingleBlock(hsd->Instance, BlockAdd);
      return HAL_ERROR;
      return HAL_OK;
  else
    return HAL_BUSY;
And for the write
  * @brief  Writes block(s) to a specified address in a card. The Data transfer
  *         is managed by DMA mode.
  * @note   This API should be followed by a check on the card state through
  *         HAL_SD_GetCardState().
  * @note   You could also check the DMA transfer process through the SD Tx
  *         interrupt event.
  * @param  hsd: Pointer to SD handle
  * @param  pData: Pointer to the buffer that will contain the data to transmit
  * @param  BlockAdd: Block Address where data will be written
  * @param  NumberOfBlocks: Number of blocks to write
  * @retval HAL status
  if(NULL == pData)
    return HAL_ERROR;
      return HAL_ERROR;
      BlockAdd *= 512U;
      return HAL_ERROR;
    else
      return HAL_ERROR;
      return HAL_OK;
  else
    return HAL_BUSY;
This completely solved my issue and I can now write to the file. Please note this error also exists in it interrupt functions (HAL_SD_WriteBlocks_IT)
