Build Error using STVD.
Question asked by Tom Gregg on Nov 29, 2017
Latest reply on Feb 26, 2018 by dhenry
I'm new to STVD, but I've used two other microcontroller IDEs in the past.  I have a standard Windows 10 machine with the standard STVD installed.  This is a simple test using Assembler code and the STM8S003F3P micro.  When I try to Build, I get an error.
The command: "asm -sym -li=Debug\main.lsr main.asm -I="C:\Program Files (x86)\STMicroelectronics\st_toolset\asm\include"  -obj=Debug\main.obj" has failed, the returned value is: 1
exit code=1.
main.obj - 1 error(s), 0 warning(s)
All the paths look good, but I can't find any documentation on the error codes.  I'm not sure what STVD is looking for.  Any ideas?  Thank you.
