David Walker
L6470: Watch the MIN_SPEED parameter
Discussion created by David Walker on Nov 27, 2017
When using the L6470 controller, watch out when using the MIN_SPEED parameter. The BEMF correction internally uses this parameter when computing the KVAL to set the duty cycle for driving the motor. The actual expression (I think) is:
This wasn't documented anywhere I could see unless I missed it.
This got me in trouble because I found I was really underdriving the motor when MIN_SPEED was set.
