M7 and H7 cache (sharable performance)
Question asked by franzi.edo on Nov 27, 2017
Latest reply on Nov 30, 2017 by waclawek.jan
Dear All,
I have some questions concerning the cache of the cortex M7 & H7 micro controller.
I use an external SDRAM and the data and instruction caches are activated. Now, if I define the region as "shareable", I lose a factor 3 in the system performance (just like if the cache is not activated). Any experience on it? Here is my MPU initialization.
Sharable ... but bad performances
static void _MPU_Configuration(void) {
      MPU->CTRL = 0x00000000; // Disable the MPU
// Attributes for the SDRAM area (0xD0000000)
      MPU->RNR = 0x00000000;      // Region 0
      MPU->RBAR = 0xD0000000;     // Address
      MPU->RASR = (0<<28)         // XN: 0 executable
               | (3<<24)         // AP: 11 read-write
               | (0<<19)         // TEX: 000 normal
               | (1<<18)         // S: 1 shareable
               | (1<<17)         // C: 1 cashable
               | (0<<16)         // B: 0 non bufferable
               | (0<<8)          // Sub-region disable
               | (22<<1)         // 8-MB
               | (1<<0);         // Region enabled
      MPU->CTRL = (1<<2)          // Enable the usage of all the default map
               | (1<<1)          // MPU is enabled during the fault
               | (1<<0);         // MPU enabled
      MEMO_SYNC_BARRIER;
      DATA_SYNC_BARRIER;
      INST_SYNC_BARRIER;
// Enable branch prediction
// Normally not necessary (always on)
      SCB->CCR |= (1<<18);
      DATA_SYNC_BARRIER;
Non sharable ... and great performances
               | (0<<18)         // S: 0 non shareable
               | (22<<1)         // 8-MB
      MEMO_SYNC_BARRIER;
      DATA_SYNC_BARRIER;
      INST_SYNC_BARRIER;
      DATA_SYNC_BARRIER;
Thank you for your advises,
Best regards
   Edo.
