SD card access through MSC
Question asked by Marina Dioto on Nov 24, 2017
Latest reply on Mar 19, 2018 by James Murray
I am trying to make a MSC USB device to access SD card files.
The computer recognizes the mass storage device, but cannot open the folder. After a while, it says the device was unrecognized.
My code from usbd_storage_if.c is like this:
int8_t STORAGE_Init_FS (uint8_t lun)
/* USER CODE BEGIN 2 */
return (USBD_OK);
/* USER CODE END 2 */
* Function Name : STORAGE_GetCapacity_FS
* Description :
* Input : None.
* Output : None.
* Return : None.
int8_t STORAGE_GetCapacity_FS (uint8_t lun, uint32_t *block_num, uint16_t *block_size)
/* USER CODE BEGIN 3 */
HAL_SD_GetCardInfo(&hsd, &SDCardInfo);
*block_num = SDCardInfo.BlockNbr / BLOCK_SIZE;
*block_size = BLOCK_SIZE;
return (USBD_OK);
/* USER CODE END 3 */
* Function Name : STORAGE_IsReady_FS
* Description :
* Input : None.
* Output : None.
* Return : None.
int8_t STORAGE_IsReady_FS (uint8_t lun)
/* USER CODE BEGIN 4 */
return (USBD_OK);
/* USER CODE END 4 */
* Function Name : STORAGE_IsWriteProtected_FS
* Description :
* Input : None.
* Output : None.
* Return : None.
int8_t STORAGE_IsWriteProtected_FS (uint8_t lun)
/* USER CODE BEGIN 5 */
return (USBD_OK);
/* USER CODE END 5 */
* Function Name : STORAGE_Read_FS
* Description :
* Input : None.
* Output : None.
* Return : None.
int8_t STORAGE_Read_FS (uint8_t lun,
uint8_t *buf,
uint32_t blk_addr,
uint16_t blk_len)
/* USER CODE BEGIN 6 */
HAL_SD_ReadBlocks(&hsd, buf, (blk_addr * BLOCK_SIZE), BLOCK_SIZE, blk_len);
return (USBD_OK);
/* USER CODE END 6 */
* Function Name : STORAGE_Write_FS
* Description :
* Input : None.
* Output : None.
* Return : None.
int8_t STORAGE_Write_FS (uint8_t lun,
uint8_t *buf,
uint32_t blk_addr,
uint16_t blk_len)
/* USER CODE BEGIN 7 */
HAL_SD_WriteBlocks(&hsd, buf, (blk_addr * BLOCK_SIZE), BLOCK_SIZE, blk_len);
return (USBD_OK);
/* USER CODE END 7 */
Does someone could help me? Maybe I am missing a step..
Thank you!!
