How to build an STemWin simulation?
Question asked by cialdi.massimiliano on Nov 16, 2017
Latest reply on May 5, 2018 by tiongpatrick Joon kiat
I'm trying to setup some gui windows using STemWin. It would be very helpful if I could compile some simulations to run on a PC (I suppose Windows, Linux is out of the question?).
I have seen that in the STM32Cube_FW_F4_V1.17.0/Middlewares/ST/ST/STemWin/Simulation/ directory there are GUISim.lib, SimulationMinGW.res and WinMain.c files, but I have not found documentation on how I should use them (note that I don't know Windows as well as I know Linux).
The STemWin Reference Manual has a chapter on simulation but does not mention these files.
Where can I find a step-by-step guide to compile an STemWin  simulation running on PC?
Where can I find some example that I can start from?
  Where can I find examples for both MSVC++ and MINGW (I suppose that MINGW is supported given the name of the foo file SimulationMinGW.res)
best regards
Max
