I want to change to hal lib because the old source has already been created.
Question asked by Study Yahoo on Nov 13, 2017
Latest reply on Nov 13, 2017 by waclawek.jan
hi 12864L LCD sample source is being applied.
Help!
// Universal KS0108 driver library
// STM32 MCU low-level driver
// (c) Rados³aw Kwiecieñ, radek@dxp.pl
#include "main.h"
#define KS0108_PORT GPIOE
#define KS0108_RS GPIO_Pin_8
#define KS0108_RW GPIO_Pin_9
#define KS0108_EN GPIO_Pin_10
#define KS0108_CS1 GPIO_Pin_11
#define KS0108_CS2 GPIO_Pin_12
#define KS0108_CS3 GPIO_Pin_13
#define KS0108_D0 0
#define DISPLAY_STATUS_BUSY 0x80
extern unsigned char screen_x;
extern unsigned char screen_y;
LL_GPIO_InitTypeDef GPIO_InitStructure;
// Delay function /for 8MHz/
void GLCD_Delay(void)
asm("nop");asm("nop");asm("nop");asm("nop");
// Enalbe Controller (0-2)
void GLCD_EnableController(unsigned char controller)
switch(controller){
case 0 : GPIO_ResetBits(KS0108_PORT, KS0108_CS1); break;
case 1 : GPIO_ResetBits(KS0108_PORT, KS0108_CS2); break;
case 2 : GPIO_ResetBits(KS0108_PORT, KS0108_CS3); break;
// Disable Controller (0-2)
void GLCD_DisableController(unsigned char controller)
switch(controller){
case 0 : GPIO_SetBits(KS0108_PORT, KS0108_CS1); break;
case 1 : GPIO_SetBits(KS0108_PORT, KS0108_CS2); break;
case 2 : GPIO_SetBits(KS0108_PORT, KS0108_CS3); break;
// Read Status byte from specified controller (0-2)
unsigned char GLCD_ReadStatus(unsigned char controller)
unsigned char status;
GPIO_StructInit(&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = 0xFF << KS0108_D0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(KS0108_PORT, &GPIO_InitStructure);
GPIO_SetBits(KS0108_PORT, KS0108_RW);
GPIO_ResetBits(KS0108_PORT, KS0108_RS);
GLCD_EnableController(controller);
GLCD_Delay();
GPIO_SetBits(KS0108_PORT, KS0108_EN);
GLCD_Delay();
status = ((GPIO_ReadInputData(KS0108_PORT) >> KS0108_D0) & 0xFF);
GPIO_ResetBits(KS0108_PORT, KS0108_EN);
GLCD_DisableController(controller);
return status;
// Write command to specified controller
void GLCD_WriteCommand(unsigned char commandToWrite, unsigned char controller)
while(GLCD_ReadStatus(controller)&DISPLAY_STATUS_BUSY);
GPIO_InitStructure.GPIO_Pin = (0xFF << KS0108_D0);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_ResetBits(KS0108_PORT, KS0108_RS | KS0108_RW);
GLCD_Delay();
GLCD_Delay();
GPIO_SetBits(KS0108_PORT, (commandToWrite << KS0108_D0));
commandToWrite ^= 0xFF;
GPIO_ResetBits(KS0108_PORT, (commandToWrite << KS0108_D0));
GLCD_Delay();
GLCD_Delay();
GLCD_Delay();
// Read data from current position
unsigned char GLCD_ReadData(void)
unsigned char tmp;
while(GLCD_ReadStatus(screen_x / 64)&DISPLAY_STATUS_BUSY);
GPIO_SetBits(KS0108_PORT, KS0108_RS | KS0108_RW);
GLCD_EnableController(screen_x / 64);
GLCD_Delay();
GLCD_Delay();
tmp = ((GPIO_ReadInputData(KS0108_PORT) >> KS0108_D0) & 0xFF);
GLCD_DisableController(screen_x / 64);
screen_x++;
return tmp;
// Write data to current position
void GLCD_WriteData(unsigned char dataToWrite)
GPIO_ResetBits(KS0108_PORT, KS0108_RW);
GLCD_Delay();
GPIO_SetBits(KS0108_PORT, KS0108_RS);
GLCD_Delay();
GPIO_SetBits(KS0108_PORT, (dataToWrite << KS0108_D0));
dataToWrite ^= 0xFF;
GPIO_ResetBits(KS0108_PORT, (dataToWrite << KS0108_D0));
GLCD_Delay();
GLCD_Delay();
GLCD_Delay();
GLCD_Delay();
screen_x++;
void GLCD_InitializePorts(void)
vu32 i;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_Write(KS0108_PORT, KS0108_CS1 | KS0108_CS2 | KS0108_CS3 | KS0108_RS | KS0108_RW | (0xFF << KS0108_D0));
unsigned char GLCD_ReadByteFromROMMemory(char * ptr)
return *(ptr);
